Question about HP DeskJet 5650 InkJet Printer
HP5650 Deskjet Carriage Stuck
The black mechanism under the ink cartridges won't move. The black plastic square under the cartridges is stuck in the up position, and the mechanism behind it won't slide back and forward as it normally does when first turned on. The carriage just makes a tiny catching movement, as if trying to move slightly left and right, when I press the blinking down arrow (resume button) or when I first turn the printer on. I have a second HP5650 next to the problem printer so I can compare reactions when attempting fixes.
  • sstaley Dec 29, 2008
    Thank you, Swan34. I've tried everything similar to your suggestion, and the problem is so basic that I couldn't push the cartridge by hand, no matter what. As it is, I've finally gotten the case off (in stages--what a MENSA challenge!!) and manually moved the little black mechanism back and forth under the ink cartridge holders--it was stuck for some reason. That's what allows the cartridges to move. I've plugged the printer in with the case still off, and now the carriage does move automatically. So I'll now reassemble and see if it actually works the way it's supposed to. Again, thanks--I'll let you know if this approach solved the problem.
    Oh-oh. Reassembled in stages, and tested after replacing each part of the case. Each time the carriage recycled, ending to the left side. After putting the cover back on, I tested again, and this time something strange happened. The carriage moved left, then all the way right, and I heard a click-snap sound as the carriage suddenly stopped. With that, I had no power to the machine and smelled an electrical short. I took the cover back off and examined the back of the main power board. When I plugged it back in, I found one little spot that was smoking--so the power board is now blown. Unless I can find a power board used--they're over $90 new--that's it for this printer. Thank you again for your suggestion, Swan34.
    President:
  • HP Master
  • 990 Answers
Hello dear; open the door let cartridge move to center, then UNPLUG the power, try to push the cartridge by hand left to right just investigate see where got stuck what cause this problem I believe you can make it. still have problem let me know.
Posted on Dec 29, 2008
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
The carriage that holds the cartridges is stuck and when I open the front panel it wont move to the center as usual. I cannot print anything obviously
I have the same printer. Underneath the home position is a rubber "wiper" that cleans the underside of the cartridges. Ink buildups get dried out and can cause the carriage to stick. You may be able to " help" the carriage out of home position by GENTLY using the belt that runs from left to right to move the carriage to the left. U nderneath where the carriage previous sat you will see 2 rubber objects. Carefully wipe off any dried up ink. This is a messy job ! Good luck.
Dec 16, 2010 | HP DeskJet 845c Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Ink is stuck in the printer. I can't get it out.f4280 deskjet
    I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
    http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
    To replace the print cartridges
    1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
    2. Open the print cartridge door.
    The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
    3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
    If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
    1 Print cartridge slot for the tri-color print cartridge
    2 Print cartridge slot for the black print cartridge
    4. Pull the print cartridge towards you out of its slot.
    6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
    1 Copper-colored contacts
    2 Plastic tape with pink pull tab (must be removed before installing)
    3 Ink nozzles under tape
    CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
    these parts can result in clogs, ink failure, and bad electrical connections.
    7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
    If you are installing the tri-color print cartridge, slide it into the left slot.
    If you are installing the black print cartridge, slide it into the right slot.
    Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
    Printer (HP5650) has full ink cartridges.window sez almost empty
    That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
    You can try this:
    1. Open printer lid so cartridges move to center of carriage.
    2. Lift clamp and remove black or color cartridge from the holder.
    3. Place cartridge on table with copper contact strip facing you.
    4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
    5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
    6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
    7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
    8. Open lid again, remove cartridge, remove tape.
    9. Reinstall cartridge and close lid.
    Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
    Doesn't always work, but you can try.
    Here are links, so you can see:
    http://www.misterinkjet.com/hp56reset.htm
    http://www.misterinkjet.com/hp57reset.htm
    Hope that helps!
    Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
    Hp 812c cartridge cradle is stuck on the right, not moving to the
    unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
    Feb 27, 2009 | HP DeskJet 812c InkJet Printer
    HP C3150 Cartridge stuck
    1. Press the Power button (c01575386.gif ) to turn the product on, if it is not already on.
    2. Open the cartridge door. The carriage might try to move into the access area at the right. Allow it to move to that position.
    3. Wait until the carriage is idle and silent.
    4. Without turning off the product, disconnect the power cord from the back of the product. WARNING: You will move parts by hand in the following steps. You must disconnect the power cord to eliminate the risk of an electrical shock and to reset the paper-feed mechanism.
    5. Looking in through either the cartridge door or the output tray, make sure the cartridges have not come loose in the carriage. Push each cartridge inward to securely lock them in place.
    6. Check for and remove any obstructions under or around the carriage that might prevent it from moving.
    7. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right.
    8. Close the cartridge door.
    9. Reconnect the power cord to the back of the product.
    10. Press the Power button (c01575386.gif ) to turn on the product.
    11. Allow the product to warm up, and then try the print job again.
    12. Check the cartridges for damage: NOTE: The product must be on or it will not release the cartridges.
    13. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it. Pull the cartridge toward you out of its slot.
      • The tri-color cartridge is on the left.
      • The black cartridge is on the right.
    14. Check the cartridges for damage, and then replace any damaged cartridges. Check for obstructions under and around the carriage. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    15. Follow these instructions to install the cartridges correctly.
      1. If you are installing a new cartridge, remove the cartridge from the packaging, and then remove the pink-protective tape.
      2. Hold the cartridge by its sides, with the contacts facing into the carriage.
      3. Slide the cartridge at a slight upward angle into the empty slot, and then gently push it until it snaps into place.
        • To install a tri-color cartridge, insert it into the left slot.
        • To install a black cartridge, insert it into the right slot. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
          Thanks, Joe
    Nov 11, 2008 | HP Photosmart 3310 Printer
    Hp deskjet 3820
    the ink cartridges get stuck on the right side. The is a square white looks as if a resting area. I don't know how to fix it.
    Aug 13, 2008 | HP DeskJet 3820 InkJet Printer
    HP DeskJet 5740
    i think ur talking about the black ink cartridge...ideally it should not get stuck but plz check if there is any plastic piece which is blocking it or there is any latch.If it gets stuck frequently its time for u to get a new printer.
    May 19, 2008 | HP DeskJet 5740 InkJet Photo Printer
    HP DeskJet 5650 InkJet Printer Logo
    438 people viewed this question
    Seeker5211
    Seeker5211
