Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 - Replacing Printhead?
Hi all. I have a Phaser 8500 that needs fixing. Currently there are 4 bars on the cyan side that is always missing whenever I do a light stripes test. Even after trying to substitute the jets I get horrific lines through all of my prints whenever I print a dark blue. (Various shades of light blue haven't caused any lines through the printouts.) I've done about a dozen light stripes tests and cleaning, and so far the only thing I've accomplished was wasting ink.
Is this a cause for replacing a printhead? If so, does anyone know where I can purchase this? Is this something I can replace myself? Please advise.
Thanks in advance!
-Lisa
  • 2 more comments
  • Lisa Dec 29, 2008
    By the way, I've spoken to the ink manufacturer to see if that was the issue. And the compatible (non-Xerox brand) ink I use does seem to cause color issues. However, after cycling through many cleanings and tests, I'm positive the aftermarket ink has been used up. I've since replaced it back with Xerox brand cyan, but it still causes the problem.
  • Lisa Dec 29, 2008
    Thanks, but I'm afraid I need a little more help. Thanks for the manual (whoever posted it). I tried to follow the steps, but I'm not exactly sure what I'm looking at other than under the cover where I refill the ink, and the exit and front covers where I open to remove a paper jam. (Would totally appreciate a step by step if possible, thanks!)
    I googled a printhead and the prices range from $15 to $400+, so I'm not sure what I need.
  • Lisa Dec 29, 2008
    I would fix it myself if I can get a clear description of what it is I'm looking at. I just downloaded the parts list pdf but am unsure of how to open the printer itself.
  • Lisa Dec 29, 2008
    Master:
  • 479 Answers
The printer is fitted with screws and locks but they r very delicate locks to get it opened as a technician is required,but if u r confident you can carry on. good luck.
Posted on Dec 29, 2008
    Novelist:
  • 163 Answers
Yes, you need a service engineer.
    Genius:
  • 1,011 Answers
Sir,
It is the problem with print head alignment. Check the manual to do it yourself
thanks
goodluck
  • 3,037 Answers
Hello nyc_goddess
yes this would be a printhead and can be ordered through Xerox
If you need anything else please let me know
Merry Christmas
bestdarngood
    President:
  • 2,110 Answers
Phaser 8500 error code 19,003.48:64663
19.003:48 is the error code 64663is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
Dec 12, 2013 | Xerox Phaser 8500/DN Printer
Got an error code - Xerox Phaser 8500 - error 07.007,40
Hi Mathew392:
Here is your problem.
7,007.49: The process motor stalled while tilting the head.
Step Questions and Actions Yes No
1 1.
Check the printhead wiring for proper
routing.
2. Remove the printhead and inspect the
printhead tilt and drive gears for ink spills.
3. Re-route the wiring.
4. Clean around the gears and printhead.
5. Did this correct the problem?
Complete. Go to Step 2.
2 1. To ensure the gears are correctly aligned,
2. Did this correct the problem?
Replace the process gearbox.
The process gear box is located on the right hand side
of the printer, you will have to remove the right side pannel to access
the gear box to see if the gears in the gear box are aligned. Let me know
if you need aditional information.
pdouglasss@hotmail.com
Dec 14, 2009 | Xerox Phaser 8500/DN Printer
Error code 13,327.42:458 How Can I Fix This?
13,327.42: The Printhead reservoir thermistor returned a bad reading, or the
reading was corrupted by ESD.
Try :
  • Are all components grounded properly?
  • Run the Printhead Reservoir Temperatur test. Did the test pass? If not replace the Printhead.
  • if it did pass check and reseat all wiring to the Printhead.
    Did this correct the problem? if not replace the print print head.
  • Go to www.iteminceonline.com and order a new one they will send you the instructions on step by step how to replace the print head and you can call them for free technical support. Goodluck
Oct 28, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560, produces cyan colored streaks whenever this ink is used. No other colors produce streaks.
You are probably using "Media Sciences" ink sticks (Non-Xerox).
This means the printheads jets are clogged, and the printhead needs replacing.
Media Sciences released a defective lot of cyan ink sticks.
They are currently replacing printheads (at their cost) if you call them.
Aug 12, 2009 | Xerox Phaser 8560DN Laser Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Xerox Phaser 8500 Error 09,005.40:100473
You don't have to take all the printer apart just the ink loader. Which is held mostly by the side covers. Get a flat head and break down the peaces left over on the cyan ink and flip upside down the ink loader and that should make it work again with no problem.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Hi Carmichael55:
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not appear to be dripping.
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to advance in the ink loader chute.
Go to
Step 3.
Remove any blockage and/ or replace the ink stick.Run clearISCfault
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run clearISCfault test to clear the error.
Hope this helps
Jul 30, 2009 | Office Equipment & Supplies
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
1 1.
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
Red is not printing properly.
That is caused by a defective print head.
Mar 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8500 excessive ink use
One of the reasons this could be happening is because you are using non-xerox ink so your print head needs to clean it out much more often. Be careful using other ink as this can destroy the machines printhead which is more expensive then the machine itself to replace. What you could try is installing the new printhead firmware, it might help! Follow the link below and good luck!
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8500_8550&country=United%20States&language=en
Niallbt
Jan 09, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
66 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
