Question about Maytag Neptune MDG5500AW Gas Dryer
I have a neptune gas dryer. Where is the igniter located? it's model number 53-4537
  • 179 Answers
Take off the front of the dryer by removing the four screws right inside the dryer door the ignitor is under the drum you cant miss it
Posted on Dec 29, 2008
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Neptune MGD9700A dryer. It is LP.
Most times that is a sign that the gas coils are weaking. I am having a little trouble with your model number so I' not sure what your part numbers will be. Get with me later if you should find the model numer to be different. On Maytag they are inside the door. I am not saying that you are wrong but that I could find only this series MGD9700SB0 One coil should be part number 694540 Coil, 60 Hz. (2 Terminal) (Main) and the other part number 694539 Coil, 60 Hz. (Split) (3 Terminal) (Pilot Position) You can find these valve in a larger photo discription on this page=> Seabreeze Appliance Parts just click on photo to enlarge.
This is the 694540 and you can find Here=> 694540
daaffda.jpg And here is the part 694539 Gas Valve
Click Here=> 694539
b7ef152.jpg If you have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 20, 2010 | Maytag Neptune MDG9700A Gas Dryer
How to turn on pilot light maytag neptune dryer
Thing is the dryer does not have a"pilot" it has an electric ignition system with and electric igniter. Go here for more: Dryer Repair Help
Go to and enter your model number into the Search box at the top of our website to see all the parts available for the unit.
appliance parts, help & more
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have a gas Gas dryer with low heat. The igniter is good, the gas valve opens and I get a flame, but it never heats up past 89 degrees. I'm guessing there is a secondary gas valve or something that kicks...
if the vent line is blocked or lint is built up in the duct where the lint filter slides into the flame will only stay on for like 5 to 10 seconds or the gas coils are bad,when the coils are starting to fail you'll have heat for the first 10 to 15 minutes and then no heat,when the coils cool down they will work again,these are the two most common problems with a gas dryer,try removing the vent line from the back of dryer and run it to see if it heats any better if so you have a block in the vent line.or run the dryer for 15 minutes and look at the flame and see if it still ignites,if not the coils are time send the brand name and model number off of the dryer,open the door look around the opening where you put the clothes in and you'll see the model number good luck.if those two things check good you could have a bad cycling thermostat located on the blower wheel housing but i would check for a block in the pipe or lint filter duct.
Nov 29, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
Sep 12, 2008 | Dryers
Maytag Neptune Gas Dryer
You have a Hi-Limit t'stat located at 12 o'clock on the flame shroud. A safety fuse is also located on the flame shroud at 1 o'clock. The flame sensor is located at 9 o'clock on the flame shroud. The Hi-Limit can be temporarily bypasses for a quick check, as well as the fuse, but do 1 at a time. Be sure to unplug the dryer before testing.
If that doesn't help, let me know if you need more assistance.
Dave E. (Illeagle)
May 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
161 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
