Question about Honeywell Programmable Heat Pump Thermostat Fan
Programing a Honeywell T8011R Programable Heat Pump Thermostat
Hi, I am looking for instructions on how to program the above named thermostat for a 5-2 Day operation. The installation guide references Form No. 69-1143 (not included with the unit). I tried looking it up on the internet but had no luck. Can you please help? Thank you in advance for your reply.
  • Anonymous Aug 06, 2008
    i need to program my honeywell t8011r thermostat
I found this link to the program manual at honeywell website:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1431.pdf
Posted on Jul 18, 2009
Http://www.universalservices1.com/site/products/honeywell/pdf/t80xx_manual.pdf
Posted on Nov 10, 2007
Trying to install honeywell 7 day program thermostat but I don't know if I have a heat pump. My initial thermostat W white O orange G green R red C blue Y yellow. When I install the Honeywell the O is not...
Look real good at the terminal block. Look at both the left side and the right side of the terminal block. O should be there! You probably do not own a heat pump. Also have patients when programing the thermostat!
Dec 30, 2014 | Heating & Cooling
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
My thermo uses B and O terminals for damper control what programable thermo do I use to replace?
Any thermostat that says that it can be used for heat pump applications will have the B and O Terminals.
Make sure that you wire the thermostat exactly as the old one was and set the thermostat up for a heat pump so that the B and O terminals are used.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 22, 2009 | Honeywell Electronic Programmable...
After RTH6400 installation heat strip is no longer actuated
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Do-It-Yourself/Programmable/5-1-1/Default.htm look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Open Questions:
Dryers Logo
1,072 people viewed this question
Top Honeywell Dryers Experts
Rob Sinbad
Rob Sinbad
Jay Finke
Jay Finke
JonSnell Electronic
JonSnell Electronic
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
