Question about Jacuzzi BM06959 White Era?? One-Piece Elongated Toilet BM06
Problems with Jacuzzi BM06959 Era One-Piece Elongated Toilet
The china has developed a crack where the bowl meets the tank and is leaking. I'm having problems finding anything online about this model. I'm looking for warranty information.
  • Anonymous May 20, 2009
    Yes I have the same problem, it is also leaking
  • 3 Answers
Here is a store front that sells that unit. It is Bob Villa's own website. I am sure they can fix you up.
Good luck and let me know if you have trouble getting the ifo you need.I have a contact at Jacuzzi that I will get hold of if this doesnt work for you.
http://www.bobvila.com/SmartBuys/Jacuzzi_BM06__Era_1_Piece_Elongated_Toilet-p466002.html
Posted on Feb 02, 2009
How do I fix a niagara stealth upper toilet tank leak?
the seal between the tank and seating would be the problem or a crack in the same area
Oct 17, 2016 | Niagara Stealth Ultra High-Efficiency -...
New toilet 540 fluidmaster water in tank keeps topping off every half hour
The problem may be the flapper that seals between the tank and bowl is leaking or the overflow pipe may have a crack in it. I wouled replace the flapper first and check the overflow pipe for cracks.
Hope this helps.
Bob
Oct 08, 2014 | American Standard Home
Toilet leaking from tank when I flush. Want to know how I can fix the problem
Common areas for tank leakage are the bolts that attach the tank to the bowl and the gasket between the tank and the bowl. The hardware could simply be loose or the seals could be deteriorated and in need of replacement. Begin by flushing the toilet to find the source of the leaking. Check for moisture on the tank attaching bolts under the tank and tighten the bolts carefully to avoid cracking the tank. If moisture is oozing out of the joint between the tank and the bowl, it will be necessary to drain and remove the tank to get access to the gasket for examination and possible replacement
Jun 28, 2013 | Home
How can I remove the Flushmate 503 to access the mounting screws at the bottom of the tank?
You will need to remove the china holding tank from the toilet bowl by removing the nuts on the underside of the china tank.
After you have the tank off the bowl, remove the two plastic lock-nuts used to mount the Flushmate into the china tank and slide the Flushmate out of the china tank.
After you install the new tank-to-bowl bolts & washers, reverse the process to reinstall the Flushmate unit and remount the china tank.
Mar 01, 2013 | Home
Jacuzzi toilet does not fill enough water in the bowl
Check to see if there is not a clog in the trap. This could keep your bowl from filling up. Also check the flapper and see if it is staying afloat in the tank long enough during the flush. Either of these could be the cause here.
Jan 14, 2013 | Jacuzzi BK37959 White Era?? Two-Piece...
Jacuzzi espree toilet leaking water from bowl without flushing. water on floor in front.
Hi!Maybe the problem of your toilet is in the mechanism inside the tank that's why its always leaking.Kindly check the tanks fittings of your toilet and replace it if necessary.
Sep 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
I am looking for a gasket between the tank and bowl which is leaking. I only have the number stamped on the inside of the tank which is BN30 BN31. Can you tell from this lid number which model toilet...
It looks like you have a Jacuzzi Perfecta.
This model came in two flavors:
  • the 300 MaP flush performance (with an elongated bowl, #BN30959), and
  • the 350 MaP (with a rounded bowl, #BN31959).
Both use the BN30 BN31 tank.
If you have trouble finding a gasket, you might consider using plumbers' putty.
(Sometimes, the old ways are the best...)
Mar 03, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
My mother has a Jacuzzi Toilet and the only number she can give me is the number stamped on the inside of the Tank as BN30 Bn31. Can you tell from that what the model is. I'm trying to get a gasket...
*********** has a Jacuzzi Perfecta.
This came in two models... one with a round bowl, the other with an elongated bowl.
Both of them use the BN30 BN31 tank.
If you have trouble tracking down a gasket, you might try using plumbers' putty.
Be aware, though, that there have been reports of the back of these tanks cracking. Check the tank to ensure that the leakage is coming from the gasketed surface, and not from a crack.
Mar 03, 2011 | Jacuzzi Home
Jacuzzi BM06959 White Era?? One-Piece Elongated Toilet BM06 Logo
215 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
