Newer monitor to older xp pc
I have two gateway desktop both are ****&less than 2 yrs old. So I took the 24"hd monitor and hooked it to a 2yrs old comq PC with a Raddion 9500 video card.Now I lost my mouse, keyboard and have no signal to the gateway or the oridg.comq monitors !!!?what and why did I blow?
  • Dan rogers
    Dan rogers May 11, 2010
    Just switching the monitor should not have given you this problem. Is there anything else you changed?
  • 43 Answers
If your monitors are displaying "no signal" they aren't receiving input from the video card. If your PC has two video outputs (onboard) try charging to the other output to see if it will come on. Also reseat your video card in its slot. Also, what can you see that lets you know the keyboard and mouse are not working?
Posted on Dec 29, 2008
Gateway lx6200 plugged in vga and hdmi cables to various monitors and no video on startup
Is the video card any good? Chances that all three monitors are defective are slim.
Mar 15, 2014 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
Gateway MD2614u, froze at start up when restart was attempted nothing appeared but a black screen. It will not restart. I have tried the battery/power reset, vacuum any dust and hooked up to another...
Actually this is a hard drive fault most likely, or a faulty had drive. If you don't have a recovery disk you are going to have to start the machine and try to do a recovery to boot repair. You can usually access this with F10 or F12, not really sure on a gateway.
Dec 29, 2010 | Gateway MD2614u Notebook
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
I have a Compaq Presario laptop with a broken
Just plugging in the monitor to your VGA port on the laptop won't make it display. You have to toggle to the exteral display, or both. Usually you have to hold down your function key, and then hit the external display key. It could be F1 thru F8, depending on your laptop model. Mine is F6. If you toggle thru the modes, your CRT should display . The missing pin is no concern!
Dec 11, 2009 | HP Compaq Presario F761US Notebook
No boot
It is the motherboard's fault...
Apr 09, 2009 | Computers & Internet
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
Maybe a bad HD. western digital 80gig, about 7 yrs old
Probably this disk is bad, but try using another testing tool to be sure before replace it.
Jan 22, 2009 | Gateway 700 XL (700XLDFM) PC Desktop
Erasing personal data to sell my computer
What exactly do you want to know? Can't make out your post.
Oct 27, 2008 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Computers & Internet Logo
David Payne
David Payne
