Question about Emerson Fans Emerson 0.8 cu. ft. 800W Microwave - Black Microwave Oven
Emerson 800w microwave model MW8780sb
The buttons for all actions work sporadically. If I keep pushing around the button, I may be succesful 90% of time. Is this an expensive fix? Should I just buy a new one?
  • Alex_toussan May 18, 2009
    The buttons have stopped working entirely for me. What can I do to fix this?
    New Friend:
How do I adjust the power level to medium
Posted on May 03, 2013
2 Suggested Answers
centurionin
  • 20 Answers
SOURCE: my microwave emerson MW8780SB doesnt
what is wrong is that your megatron went bad, is this a counter top unit or is it a built in? if it is a built in i would suggest fixing it, and if it is a really expensive counter top i would fix it, but the part cost about $80 to $100. so it would be up to you. if you want to go for the fix write me back and i will walk you through it.
Posted on Dec 22, 2008
Were do I find a replacment light bulb for my Emerson microwave. Model# MW8780SB
Emerson Microwave Parts Here is the manufacturer's number for your part 26QBP0930 The website provided carries the part.
Dec 03, 2014 | Microwave Ovens
HOW DO I program it to run 90 seconds?
Thank you for your inquiry, friend!
I see you would like to run your Frigidaire microwave for 90 seconds. Typically, you would push the "9" and "0" buttons then the start button to start your microwave for 90 seconds. If these steps do not help with programming could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your microwave. I hope this information is helpful to some degree. -Matt
Oct 08, 2014 | Frigidaire Microwave Ovens
I have emerson microwave and it keeps running and doesn't stop even after pressing stop button and none of the timing buttons are working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 30, 2010 | Emerson MW8775W Microwave Oven
MICROWAVE GOLD MICRO DOES NOT OPEN
sound likes the push button spring broke or popped out of place. if you unplug unit remove all screws going around the back edges. take panel off all the way around ,then you will be able to check spring and bbutton. the ones ive worked on the puch button cradle is usually broken and can be replaced as long as its not 20-30 yrs old.do it yourself 15-30 dollars in shop repair 65-95, in home service around 85-145.00 dollars. depending were you live.
Sep 16, 2009 | Whirlpool RMC275PD Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
'Start' button won't depress, seems jammed; timer knob broke off
the button is stuck because of food buildup over the years underneath the button, this happens even to newer ones after about a year of use, new microwaves are cheap and the lower end models start at only $35 from walmart I would reccomend buying a new one, newer microwaves use less power and are more effecient so a new one will pay for itself in saved electricty costs after about 2-3 years of use.
May 11, 2009 | Emerson Microwave Ovens
My microwave emerson MW8780SB doesnt heat everything else work
Dec 22, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
ARG!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Many Emerson microwave manuals are available here: http://www.emersonradio.com/owners/MWO%20manual/
Aug 07, 2007 | Emerson MW8779W Microwave Oven
Emerson Fans Emerson 0.8 cu. ft. 800W Microwave - Black Microwave Oven Logo
960 people viewed this question
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
