Question about Whirlpool GD5SHAX Side by Side Refrigerator
The light and digital controls on the refrigerator side dont work
The refrigerator seems to be running and cooling, but the inside lights on the refrigerator side as well and the digital display is not. The lights on the freezer side are working.
I checked the bulb and it is good. I check the door switch and it moves freely. What could be the cause of the issue?
Model GS5SHAXNL00 Whirlpool.
  • Anonymous Dec 30, 2008
    I have the same problem, I will be using my homeowners warranty to get this fixed since all my whirlpool gold appliances are covered.
  • kbilderback Apr 08, 2009
    The digital display is not working on my Whirlpool Gold Conquest. The light bulb won't come on either. We checked the bulb and yes, it works. It is cooling just fine, we just don't have a light or digital display anymore???
    Problem Solver:
  • 5 Answers
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Posted on Dec 31, 2008
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
GE refrigerator is not working. the lights are on in the inside of fride and freezer but the fridge isn't running. My external digital temperature controls, water dispenser, ice cube dispenser, is not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
qrtgfs
Jun 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The digital display resets to 0 F for BOTH the Freezer and Refrigerator after I change the temps (for eg to -4F for the freezer and 34F for the refrigerator) Also the the refrigerator and freezer are...
The OF OF display is the OFF setting, used for display purposes, so the light and controls light, but the refrigerator does not run while it is on display at a dealer. Try pushing in and holding the top two buttons on the left side of the display for about 5 seconds at the same time to get it out of the display mode. You should be able to set temps then.
Jun 20, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Refrigerator section not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
My refrigerator stopped cooling, but I still have power and lights, however, my digital cooling settings are no longer lit. Is it possible my board is bad and how do I go about fixing this problem, or can...
check back side of your fridge touch the motor compressor running or not if not running check the electronics board and make voltage check from electronics board to motor compressor. if the compressor running touch the one side of copper tube if have hot one side. if have hot your freon ok check the cooling fan inside the freezer side ok good lock
Jan 01, 2010 | Refrigerators
GE Side By Side Stopped Working
Either a bad interface\display board or a bad main computer. I would try the main computer first.
Jun 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side-by-side Refrigerator too cold, runs all the time
If the problem is in the vegetable crisper drawer primarily, Google "WR49X10045". This is a simple fix kit for a design flaw.
Nov 28, 2007 | Refrigerators
Both compartments not cooling
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section. http://tinyurl.com/3533ao
Jan 28, 2007 | Maytag MCD2257HES Side by Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
396 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
