Question about Acer TravelMate 2300 Notebook
Aspire 5520g lcd display problem!! external monit?r display active no problem in ternal LCD display m?nitor data problem nothing display screen data
    Sergeant:
  • 279 Answers
Try using the Fn + F5 key combination that switches with display your video is sent to. Post back how it goes.
Posted on Dec 29, 2008
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
I have an acer 5520g, the screen remains black, have tried fn f4, takentn battery out held power button down, still nothing anyideas please?
if the computer seems to be booting you might have a bad lcd back light what you can do to check is hook up a external monitor to the unit,
let me know if you have questions
Oct 02, 2010 | Acer Aspire 5520-5156 Laptop
ACER ASPIRE HAS NO DISPLAY
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 07, 2010 | Acer Aspire 1690 Notebook
Switch to alternate moniter using keys. original moniter is broken
Fn+F7 Toggles the display between the computer screen (LCD), a connected external display, and both the LCD and an
external display.
Select one display when playing a DVD. Connect the cable(s) before you turn on the computer; otherwise, Fn+F7 will not
work. You cannot use the Fn+F7 function to switch between the LCD and an external display once a DVD is inserted into
the optical drive.
Below is the link to the user manual for your notebook.....
http://www.docs.sony.com/release/PCGGRT250.pdf
Aug 11, 2010 | Sony VAIO GRT250 Notebook
Dell latitude d60..the laptop wont display without external monit
Seems that you have a loose LCD screen cable connection. You will need to disassemble the laptop & make sure the LCD screen cable connection is tight.
Please check this link for more details:
http://www.laptopparts101.com/lcd-screen-video-cable/
Feb 23, 2010 | Dell Latitude D600 Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Black screen
if you dont have any view on external monitor too  there so 2 reasons for.  1 is mainboard (graphic chip) 2 is LCD data cable that comes from Mainboard and goes to LCD.  need to go to Service
Apr 17, 2009 | Compaq Presario Notebook
Moniter will not show
Attach a external monitor to the laptop, it will have a VGA connection on the back or side. You will need to press, function and one of the F keys, F5 or F8 which are standard ones. So function and an F key. This will rotate the display from the laptop to the monitor and vice versa. If you get the display on the external monitor then you have an LCD or inverta(controls power to LCD screen) issue.
If there is no display to the internal or external, then you have a bad motherboard.
Jan 16, 2009 | Acer Aspire 5610-4648 Notebook
Moniter problem
the LCD screen is damaged.
hope this helps
Jan 08, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
