Question about Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 keeps switching off after a short while
The dryer turns off after about 10-20 seconds and then may or maynot start when pressing the on button. Could this be the relay, I only ask as there is a spark within the case when the dryer cuts out.
  • dommon Dec 29, 2008
    Thanks,
    I have ordered new relay, so fingers crossed.
  • Hotpoint Master
  • 3,463 Answers
Yes, it sounds like the relay is the prob
It is located at the top behind the console panel.
It is a clear plastic covered box about 3" long, and held in place by 2 screws.
Changing this should solve the prob.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
Trips electric after a few seconds tdc30
your dryer has problem with the heater.to confirm the same u just switch of heater and start dryer.solution is u have to replace tha heater.
Jan 13, 2014 | Hotpoint TDC32 Electric Dryer
Hotpoint condenser dryer
hi take lid off the start switch clips in from the back panel
May 12, 2013 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 dryer door safety switch
look inside frame by door take out switch and replace it
Apr 08, 2012 | Hotpoint TDC32 Electric Dryer
When I start dryer it starts but stops as soon as I let off the start switch
Hi.
The normal cause for this is a start relay (Part No:1701624) that has failed.
It sits inside the front panel roughly behind the start button. Its purpose is to keep the machine running when you let go of the button.
Cost is roughlt £26.00
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Hotpoint TDC32 Electric Dryer
Have a hotpoint CTD40 dryer and everytime switching it on to dry it blows a fuse. Any help please?
Sounds like short circuit you could disconnect element wire to see if still blows if not its the element, if still then elsewhere...
Oct 03, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint tdc32
How do I put a new belt on my tumble dryer
Nov 08, 2008 | Hotpoint TDC32 Electric Dryer
1. see if you have 220 at the plug, the dryer will run on 110 but won't heat.
2. Check the heating coil, it could be broken.
Jul 02, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
188 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
