Question about Denon AVR-4802 Receiver
Receiver shuts off during action effect sounds on my DVD/BR
The receiver will kick off during explosions or load music in a movie scene. The stand by light will flash.
I need to re start the receiver, but it keeps happening. What do you recommend?
  • Denon Master
  • 19,396 Answers
I quote from you : "The receiver will kick off during explosions or load music in a movie scene. The stand by light will flash. "
That means that either there is a short on the cable, or the power amp IC is failing.
The second is more likely.
Posted on Jan 09, 2009
  • 4,234 Answers
There are a number of possibilites that can cause this. I will assume that this unit has been in operation for some time so that no changes have been introduced which could explain this. That being said, lets look at the possible causes:
1) Incorrect impedence of speakers - This has been mentioned and would not normally be a problem at lower volume levels because the amp could still handle the load although working too hard, generating more heat than normal.
2) Internal short in speakers - While remote, when the speakers are reproducing the explosions, the cones move more than they normally would possibly exposing a portion of the voice coil to the magnet. If there is a defect, the coil could be shorting to the speaker frame inside the "gap" (area between the magnet and frame where the coil moves). This one will be hard to prove easily.
3) The front end of the receiver is passing along some DC curernt that at the increased volume level is sufficient to trigger the protection circuit. The output should be AC only. Any DC voltage over about 0.1 - 0.2V will cause the protection circuit to kick in.
In order to find out what the problem is, some measurements will need to be taken. If you have a DVM, try placing it acros the speaker terminals measuring the DC voltage. It should read close to 0. If not, then the amp has a problem that needs to be addressed. Please note that the system may appear to function correctly even with some DC voltage. This DC will tend to heat up the voice coil and untimately fry the speakers.
Keep us posted.
Dan
Posted on Jan 06, 2009
    Sergeant:
  • 367 Answers
Just wondering if you still need assistance with this issue. If so let us know.
Thanks
Rob
  • 492 Answers
As posted in solution one this is an issue having to do with the protection feature.  Possible problems are:
1.  Speaker wire is not of proper gauge or impedance. 2.  Speakers are not of proper impedance. 3.  You are trying to hear the sounds at a higher volume than that of what the product is able to create. 4. Capacitors are going bad in the amplifier.
Solutions: Take the manual or obtain the manual, and get the recommended wires and or speakers. Keep the volume at half level for movie and music reproduction and slowly step up from that level to find what your product is capable of reproducing. If all else fails above it is more than likely that the capacitors are going bad and will need to be replaced by and authorized service center.
  • 728 Answers
Check to make sure you do not have a short in the cord for the speakers that is causing it to pull more power than is supplied, causing it to overload and cut off, going in to protective mode so that it will not catch fire from too much power use. Do this by checking the connections leading to the speakers and make sure they are in firmly in the speaker and the receiver and that they are not broken or faulty. If problem persists, try getting new cords to replace the old ones.
    Sergeant:
  • 237 Answers
Try these guys, this seems to be a common problem
but not yet documented!
Denon Technical Support, Operational Support and Customer Service
Denon offers in-house factory Technical Support through our New Jersey location. Product Operational Support and Customer Service is also available at this location. Our contact information is as follows:
Phone Hours of Operation: 9:00AM to 5:00PM ET, M-F
Voice:
(800) 497-8921 Customer Service & Technical Support
Fax:
(201) 762-6695 Tech Support and Customer Service
  • 679 Answers
Please provide some more infformation/
Thanks for using FixYa
  • 66 Answers
You have an overload limit switch which shuts the unit down to protect catistrofic failure. Be sure you are not overloading with incorrect speaker load
    Genius:
  • 1,011 Answers
Sir,
Sounds like the overload protection is cutting in. What impedance speakers do you have connected to the A and B speaker connections? If the impedance is too low the receiver will try to output too much current and the system will overload.
Also check this Link
Plz also tell me the brand name and model no.?
thanks
good luck
  • 916 Answers
I've come to three possible solutions for this problem.
Check to see if your speaker leads are defective, corroded, thread-bare or very thin. If they are not check to see need to replace the speaker wires.
Otherwise your amp is clipping. The protection circuit on your amp is detecting square wave/clipping. You're trying to push the amp past it's max output. You're going to need a bigger amp.
Posted on Dec 29, 2008
  • 1,800 Answers
This is a bass issue try to decrerase the bass level.
if that is not helping well i recommend u with a factory reset.
    Master:
  • 413 Answers
Not sure about the music in a movie scene. But it does sound like it has an auto shut off so it doesn't blow the speakers
  • 10,594 Answers
I would recommend to...
Check speaker wires, should be connected properly.
If any extra speaker is attached, that is not recommended by
manufacturer, remove it from unit.
Kick OFF (protection activation) seems impedance issue between speakers and amplifiers.
  • Shahid Electronics
    Shahid Electronics Jan 06, 2009
    Rejecting solutions without any feedback? How can we move further then to sort out problem?
    Keep volume very low of receiver and enjoy sound system. This is only solution as you are not providing any more info.
    Genius:
  • 2,920 Answers
Try turning the volume down some. if that dosent help try running it on external speakers
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
While not normal, this could be expected. The amplifier section of the receiver is pushing so many watts into the speakers, sometimes to the point of clipping or over driving. The built-in protection senses the too much power and shuts the system down. Workarounds could be:
  • lower the volume a little;
  • lower the BASS a little;
  • disable LOUDness;
  • relocate the speakers in such a way as sound is distributed more evenly or more focused to your preference. In that way, the volume could be lowered without sacrificing listening level;
  • in some cases, the speakers may require check with an ohmmeter to verify that they are still within ohmage/specs.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 29, 2008
    You could also add more speakers to be connected in series with the original speakers thus increasing their impedance making the amplifier's auto protect think it is safe to maintain high volume on "explosions or load music".
    Cheers.
  • Louie  Role
    Louie Role Jan 06, 2009
    Any updates on developments or even the lack of any?
  • 15,935 Answers
Sthe subwoofer is bottoming out at the bump plate causing it to ground out. Either turn down the gain, or upgrade to a subwoofer that will take the abuse at the volume you are accustomed.
    Novelist:
  • 163 Answers
Will you tried it to reset?
Hi, I have a Yamaha HTR - 6130 that seems O.K. until loud action scenes & explosions,then it shuts itself off.
There are two causes for this. One that there is a fault on the amp that is causing an overload circuit to trip and shut itself down. Or the settings of your speakers levels are wrong. So you are turning it up to hear the quiet parts of movies and therefore when louder sections come along your are driving the amp too much.
Some DVD discs that have THX on them have a sound set up on them. If you have one access the THX sound menu on the disc and adjust your speakers to produce the correct levels. If it does happen after that there's a fault.
By the way most of the George Lucas films (Star Wars) will have THX on them.
Aug 05, 2013 | Yamaha HTR-6130 Receiver
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
When playing dvd or or on video 3 playing a directv movie. Receiver keeps shutting off and the screen says protect. Seems to do it when the movie scene gets loud.
check your wires if there not touching behind the speakers and receiver. when it says protect this means something is shorting out or crossing over. one other thing it may be is if a speaker is starting to go bad. (please rate)
Dec 21, 2010 | Onkyo TX-DS595 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Volume Control
I had the same issue, there is a Late night mode on the remote that minimizes the volume of a loud scene so you don't have the constantly adjust the volume. Works great if you are trying to watch a movie while others are trying to sleep.
Dec 15, 2008 | Onkyo HTR500 Receiver
Receiver shuts off abruptly when loud sounds are heard.
Are they new speakers you are using? some receivers have a overload seting so you don't mess up or blow anything, sometimes this can interfear with your music, etc..
Oct 29, 2008 | Audio Players & Recorders
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Jan 11, 2008 | Onkyo HTR500 Receiver
Sony STR-DE475 - Sound levels dropping
When did this start? Did it ever work right?
How's the sound from your TV speakers by itself and from DVD? The same? Problem's in the TV.
If it's just the receiver doing it from both sources that's where we start.
Check the settings for dynamic range (ratio of loud sounds to soft sounds) in both your receiver and your cable TV tuner. Many devices have a setting sometimes called "MidNight Mode" to be used in the event you're listening while someone else might be sleeping or otherwise would be disturbed by the TV volume.
The assumption is that you will turn the TV down but that normally means you would lose the quiet programming in the background nosie of your home. Through the magic of dynamic compression the quiter sounds are raised to audibility while loud things like explosions and fanfares will be limited in volume. Depending on the design and whatever the broadcaster is doing to the sound themselves this could be anywhere from pleasingly effective to aggravatingly inconsistent with odd variations in the levels.
Hope this helps.
Dec 17, 2007 | Sony STR-DE475 Receiver
Shutting off during a loud part of a movie
Its eather a defect with the reciver top end shut down /over bias system , Or the speakers could be partially shorted, such as instead of being 8 ohms, the speakers could have a few shorted windings from a loud music event?? I would take the speakers in to be checked under load. NOT just checked for resistance.. A regular shop may not know how to do this BUT tell them you need to put the speakers under a load and then measure the resistance . GOOD LUCK
Jun 25, 2006 | Yamaha RX-V550 Receiver
Denon AVR-4802 Receiver Logo
91 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
