Error 009-936 xerox 7235
Copier scans then puts up error code & stops
    Champion:
  • 241 Answers
Check life of drum unit
replace it
Posted on Aug 06, 2014
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 208 Answers
SOURCE: xerox 212 copier
Most likely replace the fuser.
And be sure you use transparencies marked for copiers only.
The U4 is an over heat because the tranaparency stuck between the heat roll and the thermistor. Causing the fuser to stay on and blow the overheat.
Posted on Dec 04, 2007
  • 2072 Answers
SOURCE: We have a Xerox M20
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Posted on Sep 22, 2008
  • 239 Answers
SOURCE: xerox 214 copier - U 4 code....what does it mean?
A U-4 code mean the machine did not reach to temperature.
On this machine check to see if the side door is completely closed.
This door also has some to close with a circuit board on the side.
Check to see on the side door if the small flat metal springs are aligned and not bent, with the power cord disconnected. If these metal springs are out of place a short can occur. Be very careful in this area. If you are not sure what you are doing do not try to service this area of the machine.
One other thing, if the machine has been stored in a very cold place, brining the machine to a room temperature will take about 2 hours for the machine's circuit boards just to warm up.
Usually on this problem, it may be a combination of problems. It means a new fuser assembly, or main circuit board. Not easy to get to, it is in the middle of the machine. Everything has to be taken apart without breaking other components.
Be very extra careful if you are doing this work yourself. This is why you should place a service call for a Xerox service rep to do the repair.
Posted on Oct 17, 2009
SOURCE: xerox color copier. model dc12 printer/copier error code 14-372.
error 9-lexmark2350
Posted on Apr 13, 2010
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Fault error occurred no. 123-333
I install xerox new machine when turn on gives error code 123-333
Jun 20, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox WorkCentre 7232 will not Scan to PC
Your error code usually means: Scanner can not find the specified folder/storage location
-wrong document path
May 21, 2009 | Xerox Office Equipment & Supplies
846 people viewed this question
k24674
Marvin
Marvin
