Question about Lakewood Oil-Filled Electric Radiator Heater
What is the lower dial for, what do the balls mean ?
This dial is on my upright Lakewwd Heater
  • 57 Answers
The red dials (I think - I can't find a pic where they are facing forward to see them) should control the wattage you have the heater set at. You can set it at 500 900 and 1500 watts usually. The first dial turned on would set the heater at 500. Turning the second dial on will set the heater at 900. And having both on will set it at 1500. And of course the more watts the more heat that will come out of the heater.
Posted on Jan 04, 2009
My upright Candy fridge freezer is 14 years old. The fridge is 5 the freezer is -27.9 how can i adjust it?
turn the dial to a lower number . wait a couple hours and check temps if not low enough set even lower number on dial till it gets where you want it .
May 12, 2015 | Candy Refrigerators
How do I empty the hvc-22
If you are meaning the DC24, like your post seems to be tied to, the manual can be found here:
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC24_Manual.pdf and the pictures for removing the canister and triggering the lower empty-hatch are on page 3 under 'Clear Bin Emptying'.
Good Luck!
Jul 13, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson ball not turning
Likely full of hair and debris. Need to remove the lower end to get to the ball hinge. Remove debris.
Jan 12, 2014 | Dyson DC15 Animal Bagless Upright Cyclonic...
How do I get the vacuum to go back to its upright position after vacuuming
The upright stabiliser is designed to lower and lock into place automatically when you raise the handle. If it doesn't seem to be doing this as usual, please call our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can provide further assistance to resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 24, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The bar isn't turning on my Dyson Ball vacuum. It is brand new, never has been used, turn it on and the bar doesn't turn around.
Greetings from GoVacuum,
The Dyson DC15 Ball is a two motor upright vacuum. Most other uprights use just a single motor that controls the suction on one end, and the roller brush on the other end.
The Dyson however is different. The DC15 has two motors, one dedicated to suction, the other dedicated to running the roller brush. You should first check to make sure that you in fact have turned on the lower motor for the carpet setting. There are two switches right next to each other, one is for the suction, the other for the roller brush, make sure both switches are turned to the on position.
If both are in the on posistion, and the brushes still don't come on, the machine also has a reset switch for the lower motor. This is here to help protect the belt from burning if something gets stuck in the vacuum while it's on. There is a little red reset button on the top of the roller brush housing (I believe on this model it's on the left side of the brush if you were vacuuming), try pressing this red reset switch.
If neither one of these suggestions fixes your machine, I would personally return the vacuum to where you bought it. There's no reason that it should not work right out of the box, and this may mean that the machine was damaged in shipping.
If you'd like some further help, please let me know by entering a clarification request to these suggestions, and I'd be more then happy to try and diagnosis this further with you.
Was this helpful to you? If so, please be sure to rate the repair tip as helpful, this will help me out a lot. I really appreciate it.
Chris J.
GoVacuum
Mar 20, 2010 | Dyson DC15 All Floors - The Ball Bagless...
While operating machine, brush does not rotate. Button is pushed in, all hair cleaned off brush. Is there a reset button? Where is it located?
Likely the wires are broken under the left hand cover not a difficult fix. Unplug the machine and remove the 4 torx screws and an access panel at the side of the ball. replace wires with new or re-connect with a splice. ensure wires are long enough to allow movement and you don't trap the wires when you replace the covers. about a 20 min job with the right tools
Sep 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
2000 Ford Taurus. How do I change a ball joint?
Lower Ball Joint Inspection
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Raise and support the vehicle.
  3. Prior to carrying out any inspection of the ball joints inspect the wheel bearing.
  4. Have an assistant pull inward and outward on the top and the bottom tire. Mount a suitable dial indicator and measure the movement between the ball joint and the lower arm. If the movement is at or exceeds 0.03 in. (0.75 mm) install a new ball joint.
Removal & Installation To Remove:
  2. Remove the knuckle from the front suspension.
  3. Remove the snap ring from the ball joint.
  4. Press the ball joint out of the knuckle with a suitable ball joint press and adapters.
Jul 04, 2009 | 2000 Ford Taurus
Where is temperature control on Kenmore power miser 12 hot water heater?
If you mean the temperature control dial, it's inside of the metal housing on the bottom of the unit. Slide the metal box up and off, and you will see the dial.
Dec 11, 2007 | Washing Machines
Lakewood Oil-Filled Electric Radiator Heater Logo
90 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
