Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Hitachi I have an Hitachi 43FDX20B HD TV monitor. When the TV is turned on and plays for a little while it turns off on it's and the red indicator light continues to blink
  • Nathan72 Nov 20, 2007
    It will turn on fine. Picture is fine, after awhile it just goes black and begins blinking the power light on and off. The picture, when you turn it on nomrally makes kind of a frequency sound, well when its blinking on and off, it makes that sound as well. Its a high pitch switching frequency sound. I simply hit it on the top and it turns back on for awhile. Had the convergence replaced already, its not the issue.
    President:
  • 4,402 Answers
If you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Posted on Dec 05, 2007
SOURCE:
My little red light in front is flashing, what can i do if anything?
if the lamp indicator is flashing that was mean you have to check the lamp inside if worn out which need to replace.if the power indicator is blinking you must look for the power supply board which failed check for any burnt parts.
Sep 05, 2012 | Hitachi 43FDX20B 43" Rear Projection...
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
The red light on front of tv is on but tv itself (picture), sound
Check all the picture bulbs works.
This is a plasma tv right?
U have it along time right?
Aug 13, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
WANT 2 KNOW 43FDX20B HITACHI TV IC NUMBER NAD PART NO
You can find OEM IC's for this model (43FDX20B) from a major Hitachi parts distributor on the link below:
Hitachi 43FDX20B Replacement Part IC
If you contact them and provide the generic number or location number of the IC, they should be able to provided you with the needed parts.
Apr 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 43fdx20b
well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
Dec 17, 2007 | Hitachi 43FDX20B 43" Rear Projection...
43fdx20b
Is it possible you have the "Video input sensor" on. It's in the menu system somewhere and turns the tv on if it senses something connected to it is turned on. Sometimes it gets confused and works opposite what it is supposed to
Dec 15, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
