Question about Whirlpool Calypso GVW9959K Top Load Washer
The LD light came on on my model gvw9959 Calypso washer. I checked the screens(clean) and the drain hose is not kinked. The water lines are also not kinked. What areas should I look for next. I am somewhat handy and have plenty of tools and a voltmeter. Do you have a sheet w/any schematics I might need to check solenoids or relays? I try to start the washer and it seems to come on for a few seconds and just stops. Thanks, Steve
  • misray Dec 30, 2008
    The LD light came on and the tub has remaining water that will not drain out. We had repairman replace impeller and the pump twice for similarproblem This machine is a piece of ****
I just had the same problem (ld) it means it is taking too long to drain. I got some help with this website so here is what I would do: take the back panel off with the two screws, next take the whirlpool insignia off the front of the washer. Under there you will find a screw, take it out and pull out about a 1/2" and then up and the top should pop up. Next take the three screws out and take the front panel off. Get a shop vac and **** the water out of the washer and have it ready for the next step. (you can use the shop vac on the drain hose and **** as much more water out as possible). Once you have the front panel off and most of the water drained, tip the washer back and lean it up against the wall or put something stable under it to keep it back. On the right you will see the pump and motor, take the two tabs on the side of the pump off and it will drop down. You should see a white hose on the left (outlet) and black on the right (inlet). With your shop vac handy take the white hose off and then the black one. Now you have the pump by itself, look in there and either something is caught in the impeller or the white splined part that matches the shaft is stripped out. Luckily for me there was just junk in the pump. Hope this helps and good luck.
Posted on Jan 05, 2009
What does LD mean
The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
  • Is the drain hose kinked or clogged?
  • Check the drain pump for clogs. Is it running?
  • Is the drain hose height greater than 96 inches?
  • Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
  • Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I correct the Ld from flashing
"Ld" Is for long drain, its taking longer than 5 minutes for your machine to drain. There might be a clog in the drain line.
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool calypso
The fault code "LD" indicates "long drain" condition. It's not only if the water drained, but how fast it drained. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If there are broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or a jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld fault code How to correct?
It isn't whether the water drained out, it is how quickly the water drained out. Common causes of the LD or long drain fault code are a kinked drain hose or some article of clothing being caught in the pump suction hose and increasing the time that it takes for the water to drain. It has to do with the cycle timer. I would look for some sort of obstruction. Also check the pump impeller for broken/missing blades and that it spins freely. If not, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld LIGHT FLASHING
I recently had the same problem. I actually took the two hoses off of the pump and found a penny in their. It was actually difficult, I couldn't figure out an easy way to get the water out first and had quite a mess. But now the washer works again.You'd have to get all the water out then flip it over, remove the bottom , theirs two clips holding together the pump mechanism, unlatch those, dissconnect the two hoses and look in and shake to see if something is jamming it.
Feb 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld error code won`t drain.or do anything starts for 10 sec and stops
Owner manual - Code Ld -says the drain hose is kinked or clogged.
Check that the hose didn't get kinked when pushed back to the wall. It's a common problem. The problem is NOT the wall drain as water would be coming out onto the floor if that was the issue.
Jan 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Display on my Whirlpool Calypso washer shows LD I checked but there is no water coming out of the hose. checked line ok.
"LD" flashes implies the drain hose is kinked or clogged. Check the line as well as the line it feeds into for a clog and make sure it is free to drain then if OK, Press STOP/CANCEL to clear the display. Hope this helps...
Aug 13, 2008 | Whirlpool Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
