Question about Home
How do you tighten bolts on Kohler toilet seats the bolt has a plastic cap?
  • 1 more comment
  • Anonymous Mar 17, 2014
    Plastic bracket broken seat fixed via rubber sleeve into toilet pan require new seat with fixing.
    Fitting 160mm apart 10mm dia
  • Anonymous Mar 23, 2014
    I need information on how to access the plastic bolts & nuts which are not acsessible from above.
    The plastic bolts and nuts are not accessable above the toilet bowl
  • 68 Answers
The caps are at the back of the toilet seat. Just under the cap cover are the bolts. You will need a meduim sized flat screw driver. Hold the nut on the bottom and use the screw driver to tighten.
The covers pry up with a small screw driver IF they are square.
If they are more circular with ears they rotate counter clockwise about 30 degrees, Then lift the lid off.
Please rate this response and Good Luck, Phil
Posted on Dec 29, 2008
Why is tank wobbly upon install on kohler archer toilet?
The tank mounting bolts could be loose or the tank could be incorrectly seated. Be careful not to tighten the bolts too much and crack the tank.
Jul 20, 2014 | KOHLER Archer Toilet Tank, White
Kohler Toilet seat bolts stuck
If the bolts are plastic or metal you will need to cut them off and install new ones from new seat or bolt kit there is no easy trick its just an easy cut them off or you could try some wd-40 or nutbuster.
Apr 12, 2014 | Kohler K-3384-2 San Raphael Elongated...
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
Self closing toilet seat enclosed, how to tighten
We have another Kohler that has a different, but similar design.
If you don't want to go the replacement part way, you MAY be able to get by with a toggle bolt solution - it depends how far below the ceramic surface the plastic expander extends.
This solution would involve lifting the cover flap over the hinge holes and drilling a hole (1/2 " or so) through center of the plastic screw. Then use a toggle bolt (with a stainless steel washer on one end) and insert the toggle bolt through so it expands on the bottom side of the ceramic surface. Tighten the toggle bolt and flip the plastic cover back over it to hide it.
If this doesn't work, you could unscrew your toggle bolt (the "wings" will fall to the floor, sorry) and then use a progressively larger drill bit to drill out the plastic screw, just as one drills out a rivet. The danger is in going too large and making contact with the ceramic, which will likely shatter (or at the very least chip) the bowl. Once you are able to drill out the plastic screw, you can use a larger size toggle bolt and make more secure contact with the back side of the ceramic bowl surface with you toggle wings.
Kohler cimarron broken seat, replacement parts don't work 2x's
No do not use metal bolt and nut as this can crack the toilet. Just go to Lowes or Home Depot and buy 2 plastic bolts , 2 plastic wing nuts, and 2 plastic washers. Install with seat through toilet holes and tighten by hand until tight. I then use pliers to tight just a turn tighter and the seat should be center as you tightened one side, then the other, and back again until tight.
Mar 17, 2013 | Kohler Cimarron Comfort Height 2-Piece 1.6...
The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
Usually there are plastic caps that snap down over the bolt head.
Shut toilet lid and get down close with a flashlight.
Seat attaches in two places.
Reach underneath and you can feel two bolts with nuts.
You don't need to see them, just feel with your hand.
The bolt head is covered with a plastic cover.
The cover is added for aesthetic purpose only.
Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
Use bigger screwdriver to tighten bolts.
You may have to keep one hand on underside to hold nut while turning bolt clockwise.
Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
Tighten bolts good and tight, but don't overdo it.
Bolts will come loose again and you can tighten more later.
Dec 13, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Feb 13, 2010 | Neptune FB1621 Murano Toilet
Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
Jan 09, 2010 | Kohler K-3386-0 Rialto one-piece...
Kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Jul 29, 2009 | Kohler - Toilet Seat - Moondance -...
Home Logo
401 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
