Question about Maytag MSD2756G Side by Side Refrigerator
Water accumulates and freezes in bottom shel
Defrost water accumulates and freezes in bottom shelf
  • 198 Answers
The drain for the defrost is blocked, probably with ice. If drain is frozen it will need to be defrosted, and a heat probe attached to the heat element and down through the drain hole. If not frozen there could be blockage in the drain cup depending on the model.
Posted on Jan 09, 2009
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
I have ice accumulation on the bottom shelf of my freeze of my Maytag side by side MSD2957DE. There seems to be water dripping down from the back inside panel. Is this something I can fix on my own
If you have an ice maker, or water dispenser turn off the water supply to the fridge temporarily, and see if the problem still exist. The solenoid water valves on some of these models accumulate mineral deposits and don't close completely after time, thereby leaking.
Sep 19, 2014 | Maytag Refrigerators
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
Jul 06, 2009 | Refrigerators
Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Nov 25, 2008 | Frigidaire Refrigerators
Ice forming on bottom of freezer section
The freezer should have a drain hole for the defrost water to flow through. This will drain into a pan outside of the freezer cabinet. If this drain tube becomes blocked it will not allow the water to drain out and it will accumulate in the bottom of the freezer section. You will have to verify that the drain is clear through to the drain pan. this can be done carefully with a piece of stiff wire. There should also be some sort of a water trap on the drain tube to prevent air from entering the freezer compartment through the drain tube.
Mar 09, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
236 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
