Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Freezer not cold enough
Have an 8 year old Amana side by side. super clean underneath, always kept dust/dog hair and all out. Fan works great. Freezer started to warm up, can only hold about 35 degrees. Fridge part is also staying warmer. Compressor seems to run a great deal more. Help?
  • 10,865 Answers
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Posted on Feb 06, 2009
What do I do if The freezer is working but the refrigerator is not cold
There may be a damper between the freezer and refrigerator. on some models this is thermostatic on others it is ran by an small motor. Look to see if the louvers are open. if not it is likely that the thermostat or motor is bad. Some even have a small fan.
Jul 29, 2014 | Amana Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
K68625FJBL01 KitchenAid Sidebyside Refrigerator Freezer compartment was not cold yesterday so I cleaned the dog hair off the coils and the freezer is still warm and fridge side is not cold enough now. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Fridge and freezer not cold enough. fan seems to blow. no motor noises can be heard. only about 4 years old.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101 ..
Oct 30, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Warm refrigerator and freezer
May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freeze works fine, food side at 50 degrees.
Is there a fan that blows air over the cooling coils in the freezer? Not sure if side-by-side fridges have this. This was the reason for my top freezer / bottom fridge. Air was not being blown around the freezer and down into the fridge.
Feb 19, 2009 | KitchenAid KSRS25IL Side by Side...
Freezer not cold enouph
replace the fan motor that is what was wrong with mine works great
Oct 06, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
501 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
