Question about SySTOR Systems (400S52) Burner
My Reillo Burner the solonide keeps cutting off preventing fuel from going to the nozzle
  • Anonymous Feb 28, 2009
    eletric air gate opens then nothing happens
I have had one solonoid coil that became weak and would not hold the valve open, most likely cause is the relay in the controller has oxidised or pitted contacts giving momentary flame often confused for failing photo cell, monitor voltage on coil, probably need new controller about $300 NZ
Posted on Apr 21, 2009
How do I wire a Beckett 12v diesel burner? I have a Beckett 12v burner igniter with a fire eye, a high limit switch, and a flow switch. This unit came with all the wires cut and missing a t stat and...
first do you have a fuel solenoid???i am a burner tech for thirty plus years.fuel solenoids are mounted on the fuel pump.flow switch.high limit switch and thermostat are connected in series to feed the fuel solenoid.
Aug 16, 2013 | Briggs & Stratton Pressure Washer...
Reillo 40 oil burner wont start
If I read correctly, you should have a pump for your fuel oil. If you are not getting anything out of the bleed screw I would suggest you start there, see if it is running, then check for clogged fuel lines, or possibly filter. Do you have a pilot light or HSI? Does that come on?
Mar 02, 2013 | Heating & Cooling
Ignites /starts will cut out after a few minutes
There are several reasons as to why this happens, and with that being said there are several things to correct this problem. I do this as preventative maintenance, remove the top section of the burner tube, this exposes the entire burner tray and internal parts. Locate the nozzle and remove it, they say you can not clean these, I say with a Q-tip, tooth pick and carb cleaner you can with out damaging it. Now behind the nozzle is a screen assembly these corrode at times so make sure to clean it as well.After cleaning up assemblies put the nozzle and filter screen back together.Next is the flame sensor, it is located below the nozzle assembly, round in shape and has a lens of sorts at the front. These collect carbon deposits, dirt, and the occasional homeless insect. It can be cleaned with a soft terry cloth rag and windex, now inspect the fuel lines for cracks, holes, or dry rot, replace if necessary. Locate the fuel pump next, on the back of it there is a foam air filter, this I clean with dawn dish soap rinse and dry really good, then put it back. Trace the fuel lines back to where they come thru the burner tube, now remove the side cover, you should see the fuel line and it goes to an in line filter. Remove the filter and I use a compressor and blow gun to clean it by blowing air backwards thru the filter, instantly clean. Inspect your lines again, replace if necessary. Replace side cover and open the fuel tank, lean the heater so the fuel runs towards the fuel filler opening. You are looking to see if water is in the tank, this happens from condensation when in storage. If there is I drain the fuel in to a clean five gallon bucket, now the fuel will float on top of the water and you should be able to see it.If there is water try to dry out the tank with a rag and remove as much water as you can. You can siphon off the fuel from the water and reuse it if you like just be careful not to siphon to far and get the water. Fill your heater with fuel, put cover back on the heater and plug it in, it should now fire up like new. Good luck
Dec 29, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Sep 25, 2010 | Heating & Cooling
GOT A KARCHER HDS755 BUT THE BURNER DOES NOT WORK.IT HAS FUEL GOING TO THE NOZZLE AND HEAPS OF SPARK.WHEN I OPERATE THE MACHINE WITH THE BURNER SWITCH ON AND FUEL LINE DISCONNECTE FROM NOZZLE,MACHINE WORKS...
Hi Please check your oil zzle is not blocked at all. Remove the burner head and renew the nozzle. If that fails you will need to check the fuel pressure from your fuel punmp which should be at least 9-10 bar.
May 25, 2010 | Garden
OIL FIRED COOKER FAULT
my stanley oil fired range fires up then cuts out
Dec 15, 2009 | Kitchen Ranges
NO FUEL AT NOZZLE
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel oil level extremely low: possible problems?
After your fuel tank is refilled let it set if possible for solids to settle. In the line near the tank is a fuel filter. This fuel filter should be changed regularly, normally annually. The air must be vented from the fuel filter though vent screws located on top of fuel filter. Do not remove the screws completely as air will vent as they are loosened. At the burner oil pump is a vent to which you can slip on a 1/4 inch hose and direct into a container. On burner start up loosen the vent at the oil pump and observe oil going into container. When solid stream of oil is seen close the vent. The vent looks like a grease fitting on an auto.
follow these instructions: One problem that can occur is the nozzle for the burner sometimes becomes plugged if solid particles make their way to it under low oil conditions. If this becomes the case you should have a heating service tech change the nozzle and fuel filter. However try the venting procedure first. You just may be O.K.
Dec 15, 2008 | Heating & Cooling
Riello oil burner
i have a reillo oil burner that fires up from cold no problem reaches the set temp and cuts out, when it tries to kick back in it keeps clicking the lockout light is not coming on and the fan is still running any ideas?
Oct 08, 2008 | SySTOR Systems (400S52) Burner
Computers & Internet Logo
201 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
