Question about Yamaha Full-Size Keyboard
YAMAHA P-140 Hey, how can i set a button on the yamaha p140 to control vst plugins in the computer ? i would like to change sounds on the vst instrument im working on a PC with logic audio 5.5 thanks, David.
  • Anonymous Mar 16, 2009
    yah i have the same problem where do i connect USB?
3 Suggested Answers
SOURCE: Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
Posted on Mar 31, 2009
  • 63 Answers
SOURCE: Yamaha P-200 electric piano does not have any
Plug in your ear phones to see if you can hear the sound that way. If not you are experiencing some internal failure in your integrated amp output.
In that case you will need to get authorised service.
Posted on Oct 06, 2009
  • 1040 Answers
SOURCE: no sound from Yamaha keyboard
Since your keyboard works fine with the PC. That means the problem is with the keyboard's Speaker. Either your speaker cable or speaker itself is not working... you have to identify that whether the problem is of speaker wire or speaker.... see that whether the service manual of your gadget is available or not.. if available then purchase the same. It will help you a lot for while repairing
Hope this has helped you....
Thanks...
Posted on Jul 08, 2010
No sound on my Yamaha Clavinova CLP-311
Try these steps:
  • Perhaps inadvertently, there is a MIDI settings are changed.
    Setting LOCAL-ON must be in the ON position.
    Do this (see Figure 1):
  • Connect AUX OUT (at rear panel) to an external amplifier. If the sound is heard, the damage was CLP311 power-amp.25893993-xykdzr1cdriwl1tmr4ngy0qt-3-1.jpg
Oct 05, 2015 | Yamaha Music
No sound on my SY77 yamaha synthesizer
1) Turn the power on.
2) While pressing the [VOICE] button, press and hold the [BANK D] button, then the [8] button. The SY77 will run the INITIAL TEST routine and display the Test Program Menu.
3) Press the [COPY] button. The SY77 will execute Test 48 'Factory Settings', automatically exit the test mode, and then return to play mode.
Mar 31, 2013 | Music
Do you need a computer to use the Novation UltraNova 37-Key Analog-Modeling Synthesizer
The Keyboard comes with inbuilt sounds (Approx 300 Presets and 200 user patches), so you can play it Live without a computer by simply taking AUX outs and it has a wall power supply adapter. You can also connect it to your computer via USB for additional sounds through VST instruments and Plugins. The USB also powers up the Keyboard without the adapter. Hope this helps.
Jun 06, 2011 | Novation UltraNova 37-Key Analog-Modeling...
Looking for music stand that fits on top of p120
These are sold online at Kraft Music
Yamaha WB53080R Music Rest
Replacement Music Rest for P120, P140, P155, PF500, PF1000
Jun 24, 2010 | Yamaha Music
I HAVE A Yamaha PSR 260. About 8 years old. Recently it became defective.: Only the display lights up . No sound. No response to any button. When volume control is turned, I can hear the faint rustle on...
This MAY be due to a key contact or button that is STUCK "on".
Often this will freeze the controller.
Make sure power adapter is the correct one... underpowered or incorrect ones cause trouble.
Mar 20, 2010 | Yamaha Music
When I power my ypt-300 the LCD lights up and
Press the FUNCTION button till "Local Control" appears and then select it "On".
It appears this may take quite a bunch of presses to get down to the Local Control option.
Refer to your manual around pages 56 and 57 to see the list you step through. Local Control is about 2/3 the way down page 57.
Refer to 59 for the simple instruction toe set Local Control on or off.
You can get a free download of the manual at:
http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail/0,,CNTID%253D62635%2526CTID%253D205000,00.html
Click on the resources tab to get to the download.
Dec 16, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
How to connect YamahaPSR-550 keyboard with PC in Cubase
You would connect the in's to the outs on the MIDI connections.
You would need a driver fro the EMU cable so that the USB will be recognized.
You LIKELY will need a soundbank EDITOR compatible with the keyboard to allow talking to the synth. Often theswe are called "plu-ins" to use with Cubase. They may already have one or it may be an option, some of which have to be purchased seperately.
Sep 18, 2009 | Yamaha Music
I am not getting any sound from my Yamaha DGX 200,
From Yamaha DGX 200 Manual
  • Q-There is no sound even when the keyboard is played or when a song is being played back.
  • A-Check that nothing is connected to the PHONES/OUTPUT jack on the rear panel. When a set of headphones is plugged into this jack, no sound is output. Check the Local Control on/off. (See page 69.)
Jul 29, 2009 | Yamaha Full-Size Keyboard
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
62 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
