Question about Cameras
Vivikai MPEG4 Digital Video camerra, DV-1288, will not turn on.
I bought a Vivikai MPEG4 Digital Video camera, Model DV-1288 from China. It worked fine for about a half hour. Now, when you open the screen, the camera doesn't turn on. The screen is totally blank. A "green" macro light comes on and that's all. I tried charging the battery (I even bought an extra battery). That is not the problem. Any ideas on what the problem is and how to fix it? Thanks you your help.
SOURCE: Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Posted on Jan 14, 2007
SOURCE: my samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Posted on Feb 01, 2009
leepania
  • 1099 Answers
SOURCE: Kodak easyshare M893 IS will not stay on. The
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 23, 2009
SOURCE: Battery will not charge
I tried putting the battery on the charger and then removing it as soon as the red led blinked on. I repeated it 35 times. No luck.
I then tried the square 9 volt battery method described by lancsamb above. I felt the 9 volt get hot so I disconnected it and tried the battery on the charger. Still got the red blinking led. I tried the 9 volt again and left it on about 20 seconds. It got warm again. I then placed the battery on the charger and voila, it is charging. Thanks for your help.
Posted on Mar 04, 2010
  • 11967 Answers
SOURCE: kodak easyshare V1073 digital camera won't turn on
Sounds like a lens problem is preventing your camera from starting. Try these... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 04, 2010
Video clips play upside down
Make sure you have a mpeg4 decoder loaded into your computer.
You could try another player too.  www.divx.com is a great mpeg4 media player to use and it is free.
Oct 30, 2008 | Jazz DV-179 Digital Camera
Not saving movies in mpeg4 format
AVI format can be interpreted as mpeg4 if you have Divx software.
You can download a Divx converter program from Divx.com
Jun 11, 2008 | Jazz DV-179 Digital Camera
Need help please
hi mary
you can the driver from Mustek DV 5300SE driver here you will be able to download to your pc .
riz.
Apr 13, 2008 | Mustek DV5300SE DIGICAM Digital Camera
I need aprogram to store video from my camera to pc direct
all you need is to convert it to smaller file, or compress the file such as MPEG4. But you must have a software first to convert it.
Dec 07, 2007 | Panasonic NV-GS30 Mini DV Digital...
Video capturing size question
You have two choices for Video size when creating MPEG4's. 320 x 240 or 160 x 120. Use the following instructions to change the size. Digital Still Camera Mode 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to CAMERA mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY. 5. Press the ENTER button to enter the submenu. 6. Turn the MENU DIAL to highlight MPEG4 SIZE. 7. Press the ENTER button. The MPEG4 SIZE toggles between 320 x 240 / 160 x 120 with each push. 8. Press Menu to Save and Exit.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
MPEG4 recordings on SCD23?
No. This model can only record JPEG still images to the memory stick.
Cameras Logo
221 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
