Question about Whirlpool MH1150XMQ Microwave Oven
Whirlpool microwave Model # MH3185XP No power?
Just shut down circuit breaker not tripped is there a fuse on the inside that has blown and I can replace?
Thanks for the help
  • greg2512 Apr 19, 2009
    was replacing range bulb on unit and when removing old bulb, the needle nose pliers slipped and hit the metal part of bulb causing spark and shut down micro power. i checked circuit breaker and gfi outlets with no problems. i found the 20 amp fuse above control panel behind top grill and replaced it. still no luck. wondering if there's another fuse somewhere, or will i have to call a tech out?
I just had a problem with mine and took the panel off and did find a fuse on the inside on the top portion of the unit. Try changing it and see if it works. Hope it helps.....
Posted on Jan 17, 2009
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
I have Whirlpool Microwave oven Model MH6110XEB-0 that has completely loss power. The outlet it is plug itno is still good with power running thru the outlet. I do not have any manuals for the microwave,...
with any luck you have just poped the inline fuse,
if you remove the control board you should be able to see the tube fuse up by the fan motor
if not the whole thing will have to come down to reach it
Oct 14, 2009 | Whirlpool MH3185XP Microwave Oven
The under unit light burned out and tripped the circuit breaker. Replaced bulb and reset breaker but light doesn't work. I see there is an internal fuse. Could this be the problem as there is no power...
These remarks are not make and model specific.
Did you test the new light bulb?
I would not normally expect a burned out light to trip a breaker.
You may have a blown fuse. I suspect the fuse you see is to protect the oven. If you popped a breaker, you may have blown a fuse. I'd be looking for a short somewhere, maybe in the wire that powers the light, maybe in the hardwire that supplies the oven.
Make sure you turn the power off before you go poking around. And, above all, avoid the silver can inside, it IS lethal.
Let me know if this helps.
A
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
My microwave just quit workin. It has absolutely no power.
Make sure breaker isnt tripped. If breaker isnt tripped just for the sake of knowing plug a fan or something you know that works in the outlet. If it works, you have probably blown fuses in the microwave you'll have to take microwave apart to get to them.
Aug 25, 2009 | Whirlpool MT4110SP 1100 Watts Microwave...
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
Have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Feb 28, 2009 | Whirlpool MH3185XP Microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
291 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
