Question about Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 mono amp 2 12 kicker cvr
I have a jl audio 500/1 mono amp and two kicker 12"cvr what is the best way to wire up the box i was told 3 differrent ways and was also told the wrong way can do damage to the amp. if you could email me back at cmann70726@yahoo.com i would appreciate it....Chris
    Problem Solver:
  • 12 Answers
Depends if its dual 2 ohm or dual 4 ohm
Posted on Jan 30, 2009
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
How do i wire my cvr in box
it depends on what class of amp u have. and what ohms the sub is. check out this link. it has all the wiring option u need. just click on the set up u havehttp://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html
Mar 22, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
How do i wire a jl w3 to a jl 500/1 mono
wire the sub in series it will give you best bang
Mar 16, 2009 | Jl Audio 12W3 Car Subwoofer
Box size
http://kicker.com/Product_Manuals/93/104 , look at the tech manual, it will give you dimensions of sealed or vented and it will give you a couple of box ideas.
Feb 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Why does My AMp turn off
  You need to use 4 guage or larger wiring with this amp. Also you need to make sure the power wire and ground wire are the same guage.(thickness)
   The ground wire needs to be as short as possible from the amp to the metal of the car.
  Make sure you are using a 14 guage or larger speaker wire form the amp to the speakers.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Which amp do you guys prefer will bumps better on the jl 12w3v2?
jl audio is a good name to stand by for amps kickers amps sound good at a high vol but not at a low vol
Nov 30, 2008 | Jl Audio E1200 Car Audio Amplifier
10w6 jl audio subwoofers
I would say since your amp is a mono, wire the 3 subs in series in the box,, with only two leads going to the amp
May 16, 2008 | Car Audio & Video
Amp settings
It's going to be mainly "what sounds best", but I'll give you a start.
  • Set the gain to 50%.
  • Set the LP filter to 12db at about 80Hz.
  • Set the infrasonic filter to ON and at about 20Hz.
  • Set the Bass EQ to ON, Q to 0.7, center freq to 40Hz, and boost to about 5dB.
The other settings are going to be based on how the system is connected to the head unit.
Mar 22, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
303 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
