Why does my Toshiba 32HL66 have a vertical dark wave on the right side of the picture?
  • cougar_1954 Dec 29, 2008
    its the problem of convergence settings or the convergence ic that has to be made proper by setting or replaced to make it look proper.
    Then how do I adjust the convergence setting?
    How do I adjust the convergence settings on my Toshiba 32HL66?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the Toshiba 32HL66 32" is a Diagonal TheaterWide 16:9 Integrated HD LCD TV. There are no convergence circuitry involve. Would it be possible for you to post an image of this "vertical dark wave"? The jpeg file must be 150kb or less.
Good luck and Thank you for using FixYa.
Posted on Dec 29, 2008
  • 19,396 Answers
If this is convergence then it is not a setting problem, more likely you will need to have convergence ICs replaced or to replace convergence board.
There are more faults that can cause swame problem, you need to have the TV tested to fix the problem.
    Novelist:
  • 163 Answers
There is a faulty IC (Display ic) so, they need to be changed.
    Master:
  • 479 Answers
Its the problem of convergence settings or the convergence ic that has to be made proper by setting or replaced to make it look proper.
HDMI connection fried by lightning in my Toshiba 32HL66 but everything else is fine. Can this be fixed?
I do not believe it can be fixed, but you can check it out with any local electrician.
Sep 15, 2013 | Toshiba 32HL66 32 in. LCD HDTV
2008 Toshiba 46XF550u flat screen TV.
tried to check first loose connection connector or cold soldered component parts like ic in the X board, which send signal at the screen panel display.if ok, look for the t-con board re seat the lvds cable connector.then if can not get with re seating the t-con board must have bad component parts.
Sep 07, 2012 | Toshiba 46XF550U 46 LCD 1080P Refurbished...
7inch vertical color lines right side of screen all th time
Hi.
This website has the service manual ($7.79) with instructions to diagnose the boards. Unfortunately I am afraid that the problem is not a board but the panel itself.
Thin vertical lines in the middle of the picture mean that the panel is gone. Here an example of lines from bad panel in Toshiba LCD:Line Picture. (discussion: Avsforum). Sometimes the lines can be dark or in bright color.
The panel costs $339 (LCD PANEL ASSY).
Because of the price of the panel, the TV is not worth repairing unless under warranty.
Even if the TV is out of warranty call Toshiba and report the problem. As you can see in AVSforum page above the problem is affecting many users.
If Toshiba doesn't offer special conditions on repair (or discount on new), the TV is not worth repairing. Replacement of the digital board will hardly be a solution.
Only if you have wide bands, scrambled or flickering, then the problem is digital board (main board) or panel.If you have the thin pixel lines, then the panel is gone.
Dec 10, 2011 | Toshiba 40RF350U 40 in. LCD TV
We have a Mitsubishi sd200u projector.The right side of the screen is dark,there is still picture but very dark.We thought it was the bulb,ordered and replaced that,and we are still having the same...
Does the dark side have a well defined straight vertical edge or is it ragged and blurry.
Is the picture still visible in the dark area, or has the picture disppeared and there's this darkness that has taken over.
I'm thinking that the optics may have been jolted. Has the unit suffered any impact or the like.
Mar 19, 2011 | Mitsubishi SD200U Multimedia Projector
Toshiba 32HL66 Audio completely out!!
you can search in ebay or other site try to do that and you may find it
May 30, 2009 | Toshiba 32HL66 32 in. LCD HDTV
Picture has a "wave" along the sides
I have the parts, very cheap. hill6399 at yahoo.
May 21, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
Feb 21, 2009 | Toshiba 57LX177 Television
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
