Question about Panasonic Lumix DMC-FX8 Digital Camera
Can't take pictures-all buttuns don't work
Camera turns on ok and i can go to all modes but none of the buttons work i can't take pictures and no zoom.When I go to the scene mode all the modes keep scroling and stop temporarely when I push any button. This problem started when I was taking pictures and using the zoom. I have replaced the battery and SD disk.No Luck!I have even banged it on the desk and still no change.
  • kferguson Dec 02, 2007
    same exact problem - turns on fine - can't zoom or take pics - when i go into a setting screen, it scrolls constantly
    Problem Solver:
  • 40 Answers
Try a different desk. yes you've done something strange to your settings to get it to totally not work + disable the buttons.
Posted on Apr 29, 2007
    Problem Solver:
  • 6 Answers
Hi, look for my answer in another fx8 topic! there is a soft reset combination. just switch to record mode, press the shooter button, hold it down, and switch the camera on. it is a some kind of reset. it worked me.
Posted on Jul 12, 2007
2 Suggested Answers
SOURCE: FX8 all button frozen
I am not sure if this is a solution. but one time, i turned on my camera when the battery is really drained. usually (when it was broken) it will automatically zoom in. but that certain period when i turned it on, even before it can zoom in, the battery drained and the camera went off. i charged the battery and when i put it back and turned on the camera, it works fine. it is still working fine. good thing i didnt had the repair center fix it, because they charge really high price.
Posted on Apr 28, 2008
When i take pictures it is blurry and i don't know how to change it's setting becaue i can't read the language of it(france) what should i do?
Rotate the mode dial to the setup mode (screwdriver and wrench) and turn the camera on. Use cursor-left/right to select Set-up2. Use cursor-up/down to select the third item (speech bubble) and press the OK button. Select the desired language and press OK.
Jun 12, 2011 | Pentax Optio 50L Digital Camera
How do i change the date stamp on my camera? Kodak Easy Share m1093
  • Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial.
  • 2
    Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu.
  • 3
    Press the "Down" button to change the selection to "None." This removes the date stamp.
  • 4
    Press "OK" to save the setting. Press "Program" to return to capture mode.
  • Oct 01, 2010 | Kodak EASYSHARE M1063 Digital Camera
    I have a Panasonic DMC-LX2 digital camera, I'm based in the UK. Has worked fine for a couple of years, but 2 weeks ago, when powered up, none of the buttons work. Screen is illuminated, lens emerges OK,...
    I just got identical situation today, and I have no clue at all. However, I figure that the camera is actually working busy like someone is holding the "UP" button continuously. To see this, power on your camera at any mode except the "Scene mode". After it's on, turn the mode select knob to "Scene mode". I saw my camera menu flashing like crazy. When you press any button, the menu should stop running. But once you don't press the button, the menu start running again.
    Please let me know if you have any update.
    Sep 21, 2010 | Cameras
    D80 Shutter Release button will not depress at all.
    What exposure mode(s)? What focus mode(s)? Can you (not your wife) take pictures?
    Oct 09, 2009 | Nikon D80 Digital Camera with 18-135mm...
    Button stuck, casuing unrepsonsiveness in all other buttons
    Most buttons on a camera are a simple raised rubber pad over a printed circuit board. The button gets pressed, a concuctive material on the bottom of the rubber pad puts a short across a printed pad. If the camera senses a short across the down button, it will ignore all other buttons. You need to take the back off the camera and the rubber button pad will probably be right in the back, clean the contact with an alcohol Qtip and you should be OK.
    Nov 23, 2008 | Leica D-lux 3 Digital Camera
    Buttons on camera won't work.
    I finally got the menu button to work by firmly pressing downward on the mode dial while turning it. Once the menu opened, I went to set-up and initialized all settings. This action reset all the settings to default and now all of the buttons are working.
    Jul 15, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
    1. Mode Dial not working, "Take-Picture-Button" not working.
    If the camera was dropped, then it's really causing those kinds of issues like mode dial and shutter button will not work.
    But you could still try these steps below:
    First, do the POWER RESET:
    - Turn off camera
    - Remove batteries for a minute
    - Reload batteries
    - Turn on camera
    Second, do the MASTER RESET
    - Press on MENU button
    - Press on the right button until you see SETUP 2
    - Scroll down until you see RESET
    - Press the right button to pick up on YES or NO
    - Press on OK/MENU button for changes to be saved - Turn off camera for a few seconds so that settings will be refreshed
    Third, if it still does the same thing, then your camera needs to be repaired by a technician.
    If you want to know where you could send it, just call the hotline of the manufacturer of your product so you could get assistance
    about this matter.
    Jan 01, 2008 | Samsung Digimax S630 Digital Camera
    In AUTO mode, pictures are all dark!
    Yes you definitely can,
    Turn on the camera.
    The mode dial can be turned to any setting.
    2. Press the button for longer than 5
    seconds.
    The message “Reset settings to default?” appears on the
    LCD monitor.
    3. Select [OK] using the left and right
    buttons, then press the button.
    The normal screen resumes when resetting is complete.
    To cancel resetting, select [Cancel] instead of [OK].
    Dec 09, 2007 | Canon PowerShot A70 Digital Camera
    Nov 11, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
    Camera Frozen
    I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
    Option No1:
    1. Try turning the camera on with the battery inserted.
    2. Now remove the battery while the camera is on.
    3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
    4. Now flip the camera's switch to ON again.
    Option No. 2:
    If you can open the Setup menu then the camera can be reset which might help:
    Turn on the camera.
    1. Press MENU SET.
    2. Press the left arrow button.
    3. Press the down arrow button.
    4. Press the right arrow button.
    5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
    Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
    Panasonic Lumix DMC-FX8 Digital Camera Logo
    366 people viewed this question
    Top Panasonic Cameras Experts
    Computer Links
    ogerfire
    Level 1 Expert
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
