Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune nd error code
My washer won't drain.
  • mnicalek Dec 30, 2008
    I checked all the hoses and took the pump off as well...no blockages there. Can there be something clogged from the tub to the drain pump and how do I check that. I do have the front panel off as well.
    How do I check the electric piece of it?
    Thanks.
    Mike
  • 640 Answers
Will heres some of the easy test,,,check drain hose for blockage,,,ckeck punp for coins always unplug unit..now this is more serious so be careful..ckeck for 120 volts at the pump..its a electric,,,,im here if you needed me
Posted on Dec 29, 2008
SOURCE: Maytag Neptune Error COde "nd"
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
aborcass
  • 2651 Answers
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
  • 32 Answers
SOURCE: maytag neptune mah8700aww wont drain, spin or put water in
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
Posted on Sep 29, 2008
SOURCE: maytag neptune washer code nd,
nd means not draining. u may to check the plastic drain pipe in back to back sure it doesnt have a kink in it, and that it is placed so that the pump inside the washing machine doesn't have to pump it too far to get to the drain.
aborcass
  • 2651 Answers
SOURCE: maytag neptune MAH 9700 AWW - error code nd
you need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
Posted on Nov 05, 2008
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
I am getting code nd on my maytag neptune washer. how can i fix?
ND code is "no drain" the washer probably has a drain plug/filter on the main pump, more than likely all you need to do is clear debris from the pump.
Jun 20, 2012 | Maytag Neptune MAH9500A Front Load Washer
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
What is error code n d on Neptune front load?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Has 33 minutes and a error message of nd--maytag Neptune tl
What is the Model number of your machine if its a FAV6800A or FAV9800A please read on.
The ND error code means No Drain.
You could have a drain line clog or a stuck Pressure Switch contacts.
See this post for past troubleshooting;
http://www.fixya.com/support/t2209123-code_nd_fav6800aww_serial_number_10
There are links to the Service Manual and I go over how to put the machine in Service Mode to check that the Pressure Switch is signaling properly.
Do you want to DIY the repair?
Let me know.........Rich
May 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I keep getting the error code nd on my Maytag neptune whats this mean?
Error ND means that there is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Maytag Neptune MAH9700 Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
210 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
