Question about Masterbuilt M30BV Deep Fryer
Just wandering how much oil to put in the 30 quart pot
How many liters to the fill line
Thanks, all i did was put water in the the pot, took a three liter jug and emptied the water into it. it takes about nine liters , thanks again. jack
Posted on Dec 30, 2008
What is the oil capacity of Mazda 3 2008
I have same car and i ussually put 4 liters on it when im doing change oil.
Mar 25, 2015 | 2008 Mazda 3
What grade of oil should I use in my 2004 GMC Envoy....10/30 or 10/40 and how many quarts if changing oil filter?
The oil recommended by the manufacturer is 5W-30. You will need 7.0 U.S. quarts or 6.6 Liters
May 17, 2011 | 2004 GMC Envoy
How much oil does a 2000 mercury cougar with a 2.0 Liter need?
3.5 - 4 quarts.but check oil dipstick and slowly add to full line remember to wipe clean reinsert to check...oil filter will need to fill as well so once oil is almost filled run engine for about a minute then shut off and fill to full line.
Mar 18, 2011 | 2000 Mercury Cougar
How much oil should i put in at an oil change on a 2001 monte carlo 3.4
Hello, this is the oil capacity of your vehicle.
I hope this info is helpfull
  • with filter change
4.1 liters
4.3 quarts
  • without filter change
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
with filter 4.3 quarts
without oil filter 4 quarts
Oct 08, 2010 | Chevrolet Chevy Cars & Trucks
I have a DurStar 7200 generator that has stopped running after 30 mins. The low oil light was lit on the control panel. I added a quart. Now it will not run more then 30 sec. Any suggestions?thanks Doug...
Since I believe the total oil capacity would be about 1.1 liter (not much more than a quart), you probably over filled it now.
When the low oil light comes on, it is supposed to stop.
Which it did.
So there was unlikely any harm.
But it probably still had half a quart in it, and not it probably have over 1.5 quarts.
If the piston can hit the oil, it will blow the bearings.
Unfortunately I can't find a manual to see capacity for sure.
And there is a diesel as well as gasoline version.
So all I can suggest is to drain all the oil, see how much you have in it, and put in just the right amount. There should be a full level or dipstick (probably with pint marks you mistook for quarts).
Sep 05, 2010 | Garden
How many quarts or oil do my 2000 dodge interpid take???
Most engines four cylinder and six cylinder are going to have a five quart oil pan. Put in four and a half quarts start the engine for a couple of minutes and shut it back off. Check the dipstick. Nine times out of ten you will need to put in the remaining one half of the fifth quart. Dodge recommends SAE 5W-30 oil in the 3.3-liter engine and SAE 10W-30 oil in the 3.5-liter engine. Selecting the proper oil for your engine will ensure that the components of your engine are protected.
Jul 08, 2010 | 2000 Dodge Intrepid
How many quarts of oil does a ford taurus take?
The recommended fill point will be 4 1/2 Quart. This includes the filter, as well. Fill to 4 1/2 Quarts. No more, or less. Valvoline SynPower Full Synthetic 5W-20 Motor Oil is the only oil to run is this particular vehicle. If you run a heavier oil in this engine, you risk clogging the head oil ports, and the timing chain tensioner oil channels, as well. This will induce massive repairs down the road.
Mar 23, 2010 | 1995 Ford Taurus
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
Feb 09, 2010 | 2000 Toyota Tacoma PreRunner
I don't know how much oil i need for an oil change
With oil filter you'll need 5 quarts. After changing oil and filter run briefly and check for leaks. Shut down the engine and check oil level is correct.
I hope this may have helped,
Tom
Oct 18, 2009 | 1993 Ford Probe
Masterbuilt M30BV Deep Fryer Logo
100 people viewed this question
Top Masterbuilt Kitchen Appliances - Others Experts
Richard Lilja
Richard Lilja
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Masterbuilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
