Question about SanDisk Sansa e250 MP3 Player
Adding/deleting/synching When i access the player through 'my computer'- shouldn't there be a folder there called 'music'? I see the video and voice folders- when i try to add a 'music' folder, its says there is already one there- but where is it?. I'm having problems understanding how to control the WMP 10- I got my player a few weeks ago so i'm slow to catch on. Every time I plug in to the USB, WMP just tries to add everything it finds on my computer. How do I control what goes on the player? Shouldn't it just be as easy as dropping and dragging into a folder through 'my computer'? All of my music is mp3 or WMA- yet I have lots of 'update subscription to synchronize' errors. I've heard that sometimes the problem is in the wripping process from cds, but I have a new batch of WMA's bought from walmart that won't synch. Terribly frustrating- it should be a simple process that I just can't find the answer to.
  • 8,596 Answers
Use Windows Media Player - help files with pictures on Microsoft website
Posted on May 26, 2008
Can't find the menu
if you pause the song that is playing the symbol next to the battery should change to a folder. when it does you press the mode button and it will bring up a menu called music mode. if select local folder at the top you can access all your music or delete the current song or delete all the songs
Jan 23, 2013 | GPX MW252S - 4GB MP3/WMA Digital Audio...
Want to organize/delete songs but don't see them on my computer..
Change your USB Mode in the settings menu from MTP to MSC and see if it helps.
Jan 04, 2009 | SanDisk Sansa E280 MP3 Player
Can't delete folders. response is devise not responding
to delete files there are 2 ways to do this.(1) first is with the on and facing you. on top the is the black menu switch. (2)hold down until it reads play music,and release (3) cycle either way until it reads delete.(4) cycle the switch until it reads del / push switch in (5) cycle to voice (6) push switch in to delete files. (cycle to exit and push switch again it should go to your music.
Second way is to plug it into a computer with plug and play.with the Trio MP3 on, the computer should open up a menu, chose open files (2) the screen should have music, voice and other files on the display. chose the voice file and click it open. use the mouse to delete files / or point and use the key board delete key to delete files. IF PLUG and Play does not open up goto MY Computer and openit up. drop down to the removeable disk and click open. you should be where you can delete the voice file. good luck and have fun.
Dec 17, 2008 | Digital Audio TRIO MP3 Player
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
Need help in adding music without using media player or other software
that is ok jsut download the utility from sands.com/sansa and enjoy adding music
but read the steps.
plz rate this post
Sep 07, 2008 | Digital Audio TRIO MP3 Player
I can't find my songs or hear them
I came across the same problem with my Muvo V100. It appears that the unit has a folder access limit of some kind (seems to be 24 folders not sure what detrmines the ones it chooses). I synch with Windows media player and it creates a folder called Music in the root. Within that folder it places sub folders named for the band that the music is from. Within those folders it creates yet further sub folders with the name of the CD the music came from and then finally within those it places the MP3 or WMA files. It appears there may be too many sub folders for the Muvo to be able read all the music. I took all of the MP3 and WMA files and pulled them out to the main Music folder. I then deleted all of the sub folders named for the bands and the albums. When I start the Muvo now it allows access to all of the songs. There may be a way within Windows media player to configure the synch so it doesn't create all of these sub folders. I've not checked. If it is then it would eliminate the manual work of pulling the music files out to the main Music sub folder.
Jul 01, 2008 | Creative Labs Muvo V100 MP3 Player
Can't delete voice recordings
Hard to tell without a model number, but in general:
  1. Connect your player to the computer.
  2. Launch Windows Explorer.
  3. Select and delete the unwanted music, pictures or video files under Philips. For voice recordings, select and delete the unwanted recording files in the Voice folder.
-Tha Mp3 Doctor
May 28, 2008 | Audio Players & Recorders
How to remove recordings from an sa3125?
May 28, 2008 | Philips Audio Players & Recorders
Synching
u shuld try to bring up a folder with the music in it after u connect it to ur computer then just delete the songs off of the folder i only did it once but it worked if it doessnt work try doing the same thing but on the media player im not completely sure if itll work tho
Mar 09, 2008 | GPX MW3337G
I have a Coby MP-C854 512 MB MP3 Player
Format the MP3 player. The owners manual should tell you how.
Jul 03, 2007 | Coby MPC-848 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
