Question about Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Desk Staion LCD Display
I just hooked up the phone recently and the LCD display is almost unreadable.....the characters are there but garbled...tried a new power supply but no luck....Any quick part replacement fix?...Also, is the operating manual for this phone available online for downloading?...thanks
    Novelist:
  • 106 Answers
That is a common problem with those types of displays, they are sensitive to heat, cold and any movement. They were used by Siemens, and almost all the other manufacturers during this time period. Unfortunately on this particular model, they are not soldered in, they are pressed on by a machine. So if you don't have a Zebra cable press machine ($1000's), and a brand new display, you can only resort to sending it in for repair. Sorry.
Posted on Jan 11, 2008
Desk station will not display caller id or kick over to answering system.
HI,thanks for posting your Question..
I found a couple of sites that give some instructions on how to use them.
http://www.batlabs.com/index.html
http://www.batlabs.com/newbie.htm
Manual.....http://www.portablecomm.com/pdf/sp50.pdf
Hope it helped...
Jun 27, 2011 | Siemens Gigaset 2420 Phone
Need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
May 14, 2008 | Siemens Gigaset 2420 Phone
Hello! I'm looking for free user manual for Siemens Gigaset 2420 Desk Staion. Tell me, please, where I can take it? Thanks.
Wow, about 3 minutews with a search engine and I got the manual.
Try here http://kb.efficient.com/display/1/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.1590692 put in 2420 on the search and the 3rd line down is gigaset cordless manuals. Click on that and you can scroll down to the 2420.
Carl
Apr 12, 2009 | Lands Phones
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
System pin reset
try using all zeros usually 5 zeros
Dec 01, 2008 | Siemens Gigaset 2420 Phone
Gigaset 2420 Siemens
You may have the wrong or defective power supply. Or, that problem is common from getting a power surge and the unit will probably have to be sent in for repair, sorry.
May 05, 2008 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Siemens 2420 Phone System
I had the same issue a while back and I believe a new power supply fixed that problem. If you know anyone with a multi-meter and they know how to use one they can tell you if your power supply is bad or not putting out enough voltage. I believe this system requires 12 volts and 400 milliamps it will say on your current power supply.
Aug 31, 2007 | Siemens Gigaset 2420 Phone
Msg-blinks no display
Hi Dan, Yes it is a very nice system, but like any device it is sensitive to electrical storms and power fluctuations. A surge or sag (AC power going up or down), can cause the sensitive digital chips to get damaged, and from my experience if you have tried resetting the unit, and your msg lites continue to flicker and the LCD is blank, it has some serious damage and needs repair or replacement.
Aug 25, 2007 | Siemens Gigaset 2420 Cordless Phone
Siemens Phone
I just replied to a similar post. This is a common problem, not only with the Siemens but most all manufacturers that used this design of display on many different devices. And in this case, the display connections are pressed on with a special machine and can't be replaced by a do it yourselfer. Sorry I can only recommend sending it in for repair.
Aug 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
758 people viewed this question
Top Siemens Lands Phones Experts
Marvin
Marvin
Jaime Hernandez
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
