Question about PANDIGITAL (DPF802) Digital Picture Frame
Images freeze during slideshow
I purchased 2 Pandigital digital photo frames for my parents for Christmas. Loaded identical images on both from my computer to internal memory of the frame. When they begin to cycle through the slide show, they freeze. Never on the same picture, never the same amount of time into the cycle. Both frames are doing it. HELP!!!
  • bladec59 Jan 29, 2009
    Exact same issue with 8" Pantouch
3 Suggested Answers
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
How do i get the music to play in my slideshow
what is the exact model #? Some of the pandigital 10.1" dont have provisions to play music
Feb 19, 2015 | PANDIGITAL 10.1-Inch Pan Image Digital...
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a smartparts picture frame.SP113mw Just loaded new pictures and first pic comes up and freezes, tried re-connecting to computer nothing. Can't use any of the buttons its locked up and can't...
The first (most obvious?) solution is to discard/destroy/disable/discombobulate the SP113MW. For my Mother-in-Law, I just deleted some of her images from built-in flash.
The SP113MW has a 128 mB flash drive that is accessible by USB, per previous suggestions. HOWEVER, the probable reason that your frame freezes on startup is that you have more than 744 images in the "Smartparts Pictures" folder on the built-in flash memory.
The SP113MW has a maximum limit of 744 images for a slideshow rotation, regardless of how much space is on the drive (that includes Built-in flash, USB, SD, or any of the drives). The default drive on startup is the built-in flash, so you may just have to delete some images to get under the 744 limit. FORGET the manufacturer's claim of "2000 images" (because it is technically correct); you can store 2000, but you'll never play a slideshow of 2000 (nor any slideshow if you have that many images). Reduce to 744 (all jpg's) and all will be well.
The other irritating thing about the SP113MW is that it does not allow the slideshow to include all drives: just one drive at a time, and that drive cannot have more than 744 images on it (or the slideshow freezes). That is why your comment about "trash" may not be a bad idea. However, mine Mother-in-Law's still works, so I accepted the limit, and it still sits on her shelf.
Sep 22, 2011 | SmartParts SPX8 Digital Picture Frame
I received a 7" pandigital
If the photo frame has a slot for an SD card, you can drag and drop the images you want to the card and then insert it into the frame. Connecting the card to the computer can be accomplished by using a card reader or, if the computer has a built-in SD slot, just insert the card.
Jan 21, 2011 | Cameras
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Slideshow freezes during slideshow
I wonder if ALL the pic's are correct Size & Format?
Feb 01, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
How to play PPT on Pandigital Electronic frame?
You cannot play a PowerPoint presentation files on the frame. However, if you add still images (JPG) and music (MP3). The frame can play it's own slideshow.
Oct 13, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Sep 20, 2009 | PANDIGITAL 7" Digital Photo Frame With...
How do I turn off the clock option during slideshows?
While the Slideshow is playing hit the setup button then go to Enable Clock Display and hit enter. Arrow to off and hit enter. That should do it.
Mar 25, 2009 | PANDIGITAL 7" Digital Photo Frame With...
PANDIGITAL (DPF802) Digital Picture Frame Logo
83 people viewed this question
Top PANDIGITAL Photography Experts
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
