To fix a Youtube video error start from repairing
your Windows registry which contains all the keys/codes for all the
programs and applications such as flash, browsers and other softwares.
You should choose a best tool which is able to fix the active-x and
file association errors to solve your problem. A recommended software
to fix such PC errors is listed at the end which you should try after
following all the guidelines given here.
After repairing your
registry and cleaning your Windows make it sure that your Flash version
is up to date. To install the most recent version first uninstall the
previous flash player through the Adobe uninstaller here: (
http://kb2.adobe.com/cps/141/tn_14157.html).
This utility will also uninstall the active-x component as well. After
doing this install the latest flash player available at their web site.
IMPORTANT
NOTE: When you are about to uninstall the older version of the flash
make it sure that you have removed the registry keys of the old program
from the Windows registry database. A registry cleaning software will
help you to remove the unwanted and corrupt registry keys which is very
helpful to make PCs clean from registry errors.
Also clear your internet history and cache before installing the newer version of Adobe Flash Player.
Have
you tried playing the videos on other browsers? If the you get the
Youtube videos error on other browsers as well then most probably it is
the problem related to the flash. However, if only one of your browser
is making trouble then also try to fix your browser. For fixing browser
especially for the file association errors which prevent programs from
opening properly repair the registry in your Windows.
Also do these steps to smoothly play the videos without any kind of Youtube video error:
* Disable firewall
* Disable pop up blocker
* Clear cookies, browsing data and history
* Restart your computer
The above guidelines allow you to fix
your Youtube Videos error. If you are looking for a quick fix and want
to try a solution that can do it almost itself then use a high
performance registry cleaner and PC optimizer software.
RegInOut
has been found the best software to fix the file association errors and
other active-x issues in the computer. It not only repairs Windows
registry ansd allows programs to run normally but it also boosts up PC
speed. By using RegInOut you will be able to really stabilize your
computer.
