Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
LG will not defrost motor making a noise like ice hitting it
After a few days an error measage appears on the front panel freezer and fridge fail.By turning fridge off and heating up the lower freezer compartment will allow you to restart the fridge and it will run for about 3 days noise free.It appears to me it is not defrosting,could it be the timer or the thermostat or the heater?
Model# lrfd22850st
  • 1 more comment
  • John-Pat Mulder
    John-Pat Mulder Jan 01, 2009
    I did not use this solution,but used the one that states cutting a piece of the styrofoam from the back panel below the defrost fan to allow the water to run down so that the ice could not build up and start hitting the fan.Just did this fix and so far so good.Thank you for all your help.
  • John-Pat Mulder
  • Jody Dalton Mar 04, 2009
    My new freezer made about 6-7 batches of ice and croaked. That was a 1 1/2 ago. I have had it repaired multiple times, had the fan replaced, etc. but nothing has fixed it yet. LG customer service is the worst on the planet!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I had this issue as well, techs replaced the control board and problem solved. Mine was done under warranty during the first year, hope yours isn't too expensive.
Posted on Dec 29, 2008
Why my amana freezer is making a lot of noise i have to turn it of on on for the noise to stop/
if noise is coming from inside freezer,,, the fan is probably hitting ice buildup,, and when you unplug fridge it thaws and noise goes away for a few days. sounds like a defrost problem.. either therostat is bad or heating element is broken and needs to be replaced
Aug 31, 2014 | Amana Refrigerators
The fridge is not cooling. Error ER DH showing on door. Freezer works fine. Was told that the PCB board is to be replaced as well as the defrost module. Cost will be approx $600. Can you advise o
The "Er dH," also known as the Defrost Heater Error message, is displayed when the unit fails to reach 46? F within 2 hours of beginning its defrost cycle. This may be an indication of the defrost heater having broken or the temperature fuse having been pulled out of its slot. Contact customer service if the problem persists after having attempted a system reset.
Quick Fix
  • Unplug the refrigerator for 30 seconds and then plug it back in. Doing this will reset all the codes. Sometimes an error appears by fault. If it does not appear again after restarting, then the refrigerator is fine. If the code appears again, then there is a problem with the defroster.
Defroster Problem
  • The error code itself means that the defroster mode has failed. This means that the defrost mechanism cannot reach 46 degrees Fahrenheit within two hours to defrost ice in the freezer properly. Unplug the refrigerator and move all the items that can spoil into a backup fridge or freezer.
  • Look in the back top of the freezer. Use a screwdriver to remove the ice maker machine that blocks the back defrost panel. Remove the two side screws and pull away the plastic cover guard. Check the wire. If it is unplugged, then secure it to see if that is the problem. If the plug is connected, then remove it to check for more problems. Look for any faulted wires on the defroster. If it appears that the wires are fine, you need to replace the defroster panel. Contact your local LG dealer for the specific part number
Read more:
Feb 28, 2014 | LG LFC21760 Bottom Freezer French Door...
JCD2289AES jennair fridge refridgerator side is not cold but the freezerside works
The fridge side is not getting enough cold air from the freezer side. This could be due to a few things. The vents from the freezer is blocked, or the evaporator fan/motor has failed, or the evaporator coil is iced up due to the defrost circuit failure.
To check which is the problem you will need to empty the freezer to you can get access to the panel that covers evaporator coil. After removing the panel check to see if the fan is turning, also note whether the evaporator coil is iced up. If it is iced up, then the defrost circuit is failed. The problems usually are a failed defrost heater, defrost timer or defrost thermostat.
Aug 12, 2010 | Jenn-Air Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Water leakage
It is possible that your refrigerator is not defrosting properly. If it has a timer defrost try to turn it slowly clockwise until you hear a click and about one minute you should hear a crackling noise indicating the freezer is in defrost. If the timer does not turn and defrost about every 8 hours I suggest you change the defrost timer. Let me Know, Thanks, Sea Breeze
Feb 26, 2009 | Kenmore Refrigerators
Noisy vibration
Remove the back panel inside the freezer (if there's a removable panel there. There is a fan behind it - may be source of your problem.
Jan 22, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Error Code ER FF
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it started working again. Then two days ago I got the error again. This time I decided to get inside there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out of it to get that back panel off. This includes the ice maker and the rails that the drawers slide on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my freezer one is a white screw high in the center and one was a gold screw in the little panel that the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm pull, but take care not to yank it too far... it's still connected by wires back there. When I pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never use it you should probably call someone.
Hope this helps!
Oct 18, 2006 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
381 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
