Question about Jenn-Air JFC2089HE French Door Refrigerator
Groaning frig My refrigerator has developed a groaning/creaking sound. It creaks for 5 seconds, rests for 2, then starts again. I thought it was the water/ice maker feed so I tried bleeding the water line, but that didn't improve anything. Could it be the compressor?
BFULLAWAY had the answer, I believe. My ice maker does the same thing, groaning and creaking for a few seconds, stopping briefly, then starts creaking again. This is due to ice stuck inside and it will make no ice as a result. Usually I see a piece of ice protruding and knock it out. Happened recently, but I saw no ice. Took a cup of hot tap water (not boiling) and poured it into the compartments where cubes form. (Made sure ice tray was in place to catch water.) I banged on the side and a misshapened cube fell out. Creaking/groaning stopped and unit began to function normally.
Posted on Oct 15, 2012
Had similar problem - ended up that the fingers that lift the ice when frozen were stuck (frozen) in the up position. Chip the ice off and stopped.
Posted on Nov 04, 2011
I had the same problem.
I emptied all the ice in the ice bin and the problem went away.
Don't know what it is but it seams to happen when we don't use much ice for a couple of months.
Posted on Jan 10, 2008
    President:
  • 1,462 Answers
Compressors don't usually make groaning or creaking noises and if the appliance is still cooling ok then doubt compressor is the source. there could be two other sources: cabinet creaking as it expands and contracts - this is quite common. system noise - the compressor is circulating a mixture of gas and liquid. on occasions this can be quite noisy but normally a gurgling noise
Posted on Apr 28, 2007
SOURCE:
After turning off power washer, it makes several creaking or groaning like noises. Never heard it before , its a craftsman power washer, is there something wrong. Or is it getting too hot. Help.
To hot. Don't let it set and run without the pressure handle being released. If you take your hand off the trigger for more than a couple minutes. Shut it down.
Jul 20, 2015 | Cars & Trucks
Creaking noise from front left when turning
check the wheel bearings and adjustment. check cv joints.
Mar 26, 2014 | 2006 Ford Mustang
There is a groaning and creaking noise coming from the dash. this started after the drivers side window control went out any thoughts? also the window will go down by itself but does not want to go back...
the little plastic safety gear on the window motor is busted-its used so kids dont stuck by breakin under pressure-easy to fix just take off door panel
Aug 18, 2010 | 1999 Oldsmobile Silhouette
Kenmore Elite Trio makes creaking/groaning sounds
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jan 30, 2009 | Jenn-Air JFC2089HE French Door...
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Breeze Steering Noise
sounds to me like ur steering pump is going (sounds like a weird humming). Dodge has had a weakness on their power steerings since the early 80's and automatic trannies as well.
If u want an experienced opinion, get rid of that car soon as u can and get a honda or toyota.
I guarantee u ur problems with that car will not end soon.
If ur noise happens only when ur sterring wheel is turned all the way to one side and especially if it's always on the same side, then it's one of the 2 axles (CV joint to be more precise) and it sounds more like a quick knocking (like a woodpecker kinda).
Hope this helps.
Oct 25, 2008 | 1997 Plymouth Breeze
Jenn-Air JFC2089HE French Door Refrigerator Logo
1,428 people viewed this question
Top Jenn-Air Refrigerators Experts
Jose Pino
john h
Carmen Mikulic
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
