Question about Emerson Smartset Clock Radio
I can't adjust the volume of the radio from LOUD!
This radio has one and one only volume-deafening!
I can turn the control with force, but it immediately
works its way back to LOUD. What can I do?
    President:
  • 814 Answers
Sorry it took so long to give you some help.This is a problem with intermittent component failure in the volume control circuit.This problem will have to serviced by a service center. They will have all the correct service information and parts to do the repair. The Emerson Customer support Telephone number is 1-800-909-1240 between the hour of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio. They will be able to tell you how to get the volume control repaired. I hope this information help you with your problem. Thank you for using FixYa and have a nice day.
Posted on Jun 13, 2009
ZX clock radio: How dor i control the volume of the alarm ? How do i swtich from buzzer to radio for wake up?
I have owned several radio alarm clocks and I have found them all fairly intuitive to operate - no instructions needed, though sometimes it takes a short time of playing around to fill in the operating details.
The alarm buzzer is generated by the audio part of the radio and so those clock radios that do have a buzzer with adjustable volume it is controlled by the radio volume control. In this case it is usually the case that falling asleep to the radio with the volume turned down results in not being woken next morning because the alarm isn't loud enough.
Switching from radio alarm to buzzer is usually intuitive but in the absence of instructions there will be a limited number of switch combinations to play around with.
Nov 07, 2017 | The Audio Players & Recorders
I work for Safeway,recently we got new telxons,they are so loud they hurt everyone's ears even at lowest volume. Can we silence them? I have to punch in CIC #'s cause beeps are too loud. Please help!
call in the work safety team as anything over 40 db is deafening and affects hearing and is a hazard
next is to turn them off until they are fixed
May 31, 2017 | Cell Phones
How do I fix a volume / sound problem on my kustom 2x12 amp
You have a bad potentiometer which is a variable resistor. Might be the switch you are turning.
May 08, 2017 | The Audio Players & Recorders
Radio/Nav is malfunctioning; unresponsive, shuts down/reboots, slow to react to inputs
The only thing that you can do is remove the unit and send it out to a factory approved repair shop, that is it no other choices.
Jun 18, 2017 | 2014 Nissan Altima
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
I have a yaesu ft-736r with no audio
Hi Jermaine,
It transmits, but no receive, are you sure, have you tried playing around with the volume control?
If, so did that make any crackling noise? If so, then this is due to lack of use of the volume control, many radios, including the old transistors with dials, would make crackling sounds when you adjusted the volume, and as I say, this is due to lack of use, So if this is the case and to get your receiving, turn the volume control up & down fully for a few minutes and while doing so your radio might receive a transmission that will be loud, quiet, loud, quiet, etc., as you play with the knob.
Keep doing so until all crackling has disapeared.
Do this often as possible when firing up your radio for the day, the more use these controls get, the better.
I hope this has answered your query.
Cheers,
Peter
May 29, 2012 | Yaesu FT-736R
I have a HT1000 with a remote shoulder mic and a attached 3.5 listen only ear piece. How do I adjust down the volume of the identifier alert tone when I key up the mic. The volume control works for general...
In the programming software their is a field that allows you to either turn off the alert tones or make them lower then your volume level. Most of the time if any of my customers are using a ear bud or headset I turn off all of of the "beeps". Michael
Dec 02, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Where do you adjust the brightness and volume
one button opens the control panel the other lets you move your options the other one lets you select mave it to brightness and or contrast select it and there we go
Mar 31, 2009 | Acer AL1916W 19" LCD Monitor
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Emerson Smartset Clock Radio Logo
163 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
