Question about Brother Office Equipment & Supplies
Brother DCP-770 will not scan by wifi must have usb cable attached to scan. Why
There is no solution! While the DCP-770 will print wirelessly it will not scan
Posted on Dec 30, 2008
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
Why can i print but not scan?
You probably need to re-install the print driver on the computer that is not scanning.
Apr 25, 2014 | Brother Office Equipment & Supplies
Brother DCP-135 unable to clean
How to Open Brother DCP-135C
Loosen + remove 3x Cross-Collar Screws on Control Panel. Rise, 2x unplug Control Cable, Control Panel release to forward. Remove 1x Cross Collar Screw front top left, remove the Casing. Remove upper Cable Covers of Scanning Unit Cables, unplug and free the Cables. Remove Scan Unit Pillar, rise complete up and release backward. Remove 3x Cross-Screws at the front top, 1x inside the Cable Compartment, 2x rear top. Remove upper Cover. Now, the Print Head is accessible.
Brother DCP-135C Oeffnen
3x Kr-KragenSchrauben an Bedienfeld oben loesen. Hochklappen, 2x Stecker abziehen, Bedien-Blende nach vorne ausklinken. 1x Kr-KragenSchraube vorne oben links loesen, Front-Verkleidungen abnehmen. Obere Kabelabdeckungen der ScannUnit abnehmen, Kabel abziehen und freilegen. ScannUnit Stuetze loesen, ganz hochklappen und nach hinten ausklinken. 3x Kr-Schrauben vorne oben, 1x im Kabelfach, 2x hinten oben loesen. Obere Verkleidung abnehmen. Jetzt ist der Druckkopf zugaenglich.
Jan 21, 2014 | Brother DCP-340CW All-In-One InkJet...
Do i need to use usb lead to install wifi on labtop use brother dcp j125
On most wifi printers, you need a USB cable to set it up the first time.
Aug 17, 2012 | Brother Office Equipment & Supplies
What kind of plug/cord do i use to plug my Brother PE-770 into my computer
Just use a regular printer type cable. On newer models, they use a regular USB connection so it's easier to use USB keys
Jan 29, 2012 | Brother PE770 Computerized Sewing Machine
Product scans but then I can't find the result
The first thing I recommend you try is a new data cable. Scanners require bi-directional communication and will fail even when the printer works. Similarly go for a direct connection instead of using a print server or USB hub. (I have a scanner that had the same problem - the preview scan started but no image saved due to a bad cable.) If you are using a parallel port connection, make sure that bi-directional communication is set for the port (in the BIOS). If you use a USB to parallel port adapter, make sure it is a bi-directional (for scanner) adapter.
I hope this helps.
Jul 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 8045D prints and copies but won't scan
Check out that the Scanner USB cable is connected to the PC apart from the printer Cable
Mar 08, 2010 | Brother DCP-8045D (Bundle) All-In-One...
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
Dcp-115c usb cannot be found (CC027)
sure..some printers need to be plugged directly into wall socket for scanner to work..try that first..
Nov 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
