Question about Pentax MZ-50 35mm SLR Camera
Small hair in view finder
Got a pentax mz50 and it has a small hair on the inside of the viewfinder how do i clean it, cleaned everything else ;thank you
    Problem Solver:
  • 15 Answers
That camera has a removable focusing screen. Usually the object(hair) is sitting on top of the focusing screen so the screen has to be dropped down to remove it. There is a clip(frame) accessable from the mirror box that needs to be un-hooked. The frame swings down and usually the screen and a brass shim(s) comes down with it. If your careful and don't actually remove the frame, screen and shim it's pretty straight forward to gently blow the hair out. After removing the hair, gently swing the frame up and clip it back in.If the frame, screen and shim actually fall out it's tricky getting them back in correctly. The screen is also very soft and scratches easily so much care is needed. If you're uncomfortable trying to attempt this then take the MZ50 to a good repair shop. We do this service free and usually while you wait. Other shops may charge you a fee to do it. If the hair is behind the eyepiece then the top cover has to be removed to get the hair out. That is a totally different problem and the camera will need to be repaired. Since the hair dosen't affect the image on the film, you may just want to live with it or have it removed when something else needs to be done when the camera has to be disassembled anyway. Hope this helps.
Posted on May 02, 2007
Cracked view finder
That would depend on which part of the viewfinder that needs repair or replacement. If it's the piece of glass at the very back, where you put your eye, it wouldn't be that expensive. If it's the prism inside the hump atop the camera then it would be quite expensive.
May 27, 2013 | Pentax K20D Digital Camera
View finder indicators are blurry
Try adjusting the viewfinder diopter as described on page 50 of the manual http://www.pentax.jp/english/support/man-pdf/x90.pdf
May 09, 2013 | Pentax X90 Digital Camera
When using any lens, the view through the viewfinder has small spots like a liquid was sprayed on a optical component. What is this and how can I fix it?
It could be on the mirror, the underside of the focusing screen, or the back of the viewfinder. All three can be inspected visually.
The back of the viewfinder can be cleaned with any window cleaner. Don't spray any directly onto the camera, but rather onto a clean microfiber cloth and then wipe the viewfinder clean.
The mirror and the focusing screen are more delicate. First try a handheld blower (NOT canned compressed air). If that doesn't do it, try a camel-hair brush. Only then resort to wiping it with a clean dry microfiber cloth. Use common sense, and avoid scratching the mirror/focusing screen.
If it's on the inside, the camera will need professional cleaning.
Sep 28, 2012 | Nikon D80 Digital Camera with 18-135mm...
The viewfinder on my Panasonic PV-DV200 needs to be cleaned. I have the instruction manual but I cannot get it to turn the 1/8 turn recommended to remove
Hi, My PV-DV200's viewfinder needed cleaned too. Try, try and try again. The entire viewfinder assembly will turn, but if it's never been removed before, it will be on extremely tight. My viewfinder has a small notch at about 1 'o' clock on top. That notch needs to be turned to about 11 'o' clock. Once there, the viewfinder slips off easily. It will come off much easier from then on.
However, simply cleaning the removed viewfinder may not be enough. You may also need to remove the two small screws on the underside of the piece that's still attached to the camera in order to get inside there and clean that too. I removed the small rectangular glass and cleaned that and behind there as well. I used a Rayban cloth (needs to be lint-free) and some Plexus, along with a dull pencil in order to get everything cleaned all along the sides of each lens.
Just double check and make sure all parts of the viewfinder are clean by slipping everything back into place prior to screwing it all back on. This will save you some time because you will probably not get everything cleaned on your first attempt.
Hope this helps!
Nov 16, 2011 | Panasonic PV-DV200 Mini DV Digital...
While in Aruba (91 degrees outside/70 degrees inside hotel room) my digital Pentax camera (Optio M50 model) developed a 'blob' in the LED view finder. It did not appear when I printed several shots to...
It certainly could be condensation. When it dried, it could have left a mark on the panel. As long as your pics turn out well, don't worry about it. If you try to take the panel off to clean it and you don't know what you're doing, you could cause major problems. However, if you're determined to do so, there are plenty of sites on Google that can show you the procedure in pictures.
Oct 27, 2010 | Pentax Cameras
Viewfinder views things backwards
Yes, most finder scopes show upside down images, it's completely normal.
This is an astronomical telescope. Even the main tube shows upside down images unless you use what is called an "erecting prism" for terrestrial viewing.
Jul 06, 2010 | Meade 70AZ-TR Telescope
There's an insect in the viewfinder... IHow do I remove it?
There is lock on black portion of view finder push it and turn it anti clockwise it will open and use hand blower n clean it
Mar 06, 2010 | Sony Handycam DCR-TRV103 Digital Camcorder
Water Damage to View Finder
Try cleaning the viewfinder with a damp (again?) soft cloth. You can use a product recommended for cleaning camera lenses. You can still use the screen to view the scene you want to shoot. (I am assuming that what you call the viewfinder is the small eye that used to equip all cameras, before it was replaced by the view screen.)
Hope it helps.
Sep 08, 2009 | Sony Cyber-Shot DSC-W220/B Digital Camera
Have lint and small specs on inside part of viewfinder, how do you clean this
It may not be the view finder. My guess is that there's some dust on the lens. It will look like the dust is inside the view finder but its actually not. Do these "spec" appear on pictures too? If yes then you will need to clean your lens/get it cleaned.
Let me know if you need more help,
Sai.
Aug 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
Dust inside my d200
The view finder and focusing screen are separate from the CCD sensor. The mirror reflects the image to the view finder until you take a picture. Then the mirror goes up, the shutter opens to expose the CCD to capture the image.
If you have a lot of dust, you should look into a cleaning kit, or have it professionally cleaned. This will show up on your images as white and/or black specks.
Jun 29, 2008 | Nikon D200 Body Only Digital Camera
Pentax MZ-50 35mm SLR Camera Logo
186 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
