Question about SanDisk Sansa Clip MP3 Player
Sansa clip 2gb wont charge when i plug into pc. i go into my computer and it wont recognise it. the screen lights up and says connected and acts like its charging ie the battery indicator flashes but after a few moments the flashing stops. help! havent even used it yet and didnt get a wall charges with it.
  • Anonymous Dec 31, 2008
    I have the exact same problem
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
My brandnew sansa clip is recognised by my
you should update new firmware first at http://forums.sandisk.com/sansa/
if it still doesn't work, change another one.
Good luck
Jan 12, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip will not turn on.
hey dude something is lose inside it has no connection to the battery but the actual port that you plug your pc in does ... myn is also like that and iv had it for a year now,,,,
Jul 09, 2009 | SanDisk Sansa Clip MP3 Player
Computer doesn't recognize MP3 player -
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 2gb clip
While the player is connected to the computer, you will not be able to go through the menu, play music, etc. Only after you have disconnected it from the PC will it work.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Connecting Problem
Unplug your Sansa. Uninstall all the Sansa software from your computer, and reinstall the clean version from the Sandisk website. Then, replug the Sansa.
-Tha Mp3 Doctor
Nov 15, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB
yu charge it erveryday, and yuve been using it everyday, so that means that it needs to charge, if it says connected tocomp and charging that means that it needs more electricity in its battery to keep, its battery running.
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
May 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
112 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
