Question about Whirlpool Duet GHW9150P Front Load Washer
My whrilpool duet washer is flashing a error code of h and f
I found that my washer would not drain which is why I was getting the F02 code. I first pulled the strainer to see if it was plugged and it wasn't. I turned the little impeller to the right of the housing and it was free moving but it moved in and out as well as turned. That made me curious. I then to a shop vac and pulled on the drain hose at the wall hook up. It pulled and I could put my hand inside the strainer housing and felt the suction.
This led me to my last tought which was to pull the pump off the strainer housing. It only took three screws and when I pulled it I saw the impeller. When I pulled pack on the impeller it cam right out of the motor and I could see the end of the shaft had sheared and the grinding sound I heard was the shaft ends grinding and it was not able to move any water from the basin.
Im now looking for a new pump cause Im sure its one unit. So far they are over $100 for the complete housing and pump. Im hoping I can just find the pump.
Posted on Dec 29, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet washer
Hi
This error code means that there is no water detected entering machine or Pressure switch trip not detected. Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
UR MAIN CONTROLLER NEEDS REPLACING. IT HAS A COMMUNICATION ERROR
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal De
