Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Fridge and freezer won't get to temp
Kenmore model#25352612200 Moved it from another house where it was working fine. Transported on its back. Once plugged in will cool a little but not all the way.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You have problem oil get in the evap call service
Posted on Apr 02, 2009
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
We had to pull our kenmore 22 s-b-s away from the wall to replace the water filter. while unplugged and empltied, we removed drawers and shelves to wash. wheeleed out onto patio (always rewmained upright)...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 19, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
I have a stainless steel Amana model ABC2037DES that was given to me. It has been plugged in for 24 hours and it is not freezing anything or making ice. The refridgerator is not cold enough either. ...
if the compressor is working it could be a thermostat problem
I think that if you check for a reset button at the back to get the compressor running , that will fix the problem
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
Fridge & Freezer won't get cold, but air is blowing
Is the compressor in the lower back working. You may short of gas . have it regassed
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bought this model from someone new, it was working great when I checked it out, transported it to our house and plugged it in the next day. Freezer works well but fridge barely cools at all. Any...
HI There,
If it was transported to to your house not in an upright position, then you may need to unplug it and wait for 8 hours to have the fluids settle before starting it again. If that is not the issue, ensure that there is ample space at the back of the unit, between the wall and the fridge to help circulate the air. Inspect the coil found at the back of the freezer for ice build up or dirt. If there is let it melt and have the unit cleaned out first before restarting.
Aug 22, 2009 | Refrigerators
My freezer is freezing great, the fridge is not cold at all! Just moved fridge into my house yesterday, bought on Craigs list
the freezer actually cools the fridge via a fan usually located in the "ceiling" of the fridge. make sure this is working and check yur temp contols make sur they are adjusted right
Aug 16, 2009 | Frigidaire FRT18G4A Top Freezer...
Freezer woks fine but the fridge not working
sounds as if the evaporaator fan inside the fridge between the fridge and freezer is out. This fan is located between the freezer and fridge in the same area as the control switch for the temp. This fan isn't hard to replace you just need to take care of the removal of the plastic cover. Once the cover is removed the fan is accessed easily. Take the model and serial number to an appliance parts house for the proper part. Good Luck
Dave
Jul 22, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Model #10657058791 freezer and fridge not cooling
Check your connections in the back make sure no wires are lose or rattled lose off of the compressor or anything like that
Feb 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
