Trimble 5600 5605 Dr200 Direct Reflex Robotic Total Station Survey Surveying Logo
Ralph Clay Posted on Oct 02, 2012
What is the maximum voltage from a battery pack that a trimble 5600 robotic can use?
Nigel Crane
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 19, 2014
Nigel Crane
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
390
Points
I use a small 12volt battery from a ride on lawn mower that has 21 amp hour rating. Best go to Trimble for the correct lead acid splitter cable. It lasts 4 days easy with constant use. Hope this helps. Nigel Crane.
Trimble 5605 DR200+ Robotic Total Station. My CDU is showing version '668-01.01 load program'. What to do?
Question edited for a lot more clarity, 'make model (what it is), fix typos, capitalize CDU and DCU (not sure which is right, the manual mentions neither).
Question moved from Motorcycles Category to model.
https://www.skcic.com.tw/file/trimble/Trimble%205600%20series_user%20manual_en.pdf
Did you change the internal battery? It sounds like you erased the operating software
Note that the battery change must be made within 2 hours; otherwise the above parameters and functions will be reset.
Contact your local distributor. If these machines are leased like the Leica Total Station, they phone home if you miss a payment or start fiddling with internals and they PUK Lock it on you.
https://www.google.com/search?q=trimble+5605+DR200%2B
Got a used Roomba 618 from a friend. put a new battery in and charged/ it just spins in circles and speaks French. can I fix
Selecting the Wi-Fi connected Roomba robot language.
Roomba comes with a default language pack for the robot's spoken messages. Each language pack vary by region.
  1. Open the iRobot HOME App and select More ? Settings ? Robot Language.
  2. Choose either from your robots Installed Languages or select from the Additional Languages.
  3. On Roomba 900 Series and i Series you can choose either from your robots Installed Languages or select from the Additional Languages.
The factory default will return the robot's languages to the default pack that came with the robot.
Languages can only be changed when on your local Wi-Fi Network.
see...
https://homesupport.irobot.com/app/answers/list/
Trimble LR21-S have a battery in side
The LR21 has an optional battery that clips on the back. There is no internal power source.
Trimble 5605 shoot distance
These units have to be periodically cleaned and calibrated and it is not a do it yourself project. http://www.martininstrument.com/repairs/
I've a problem with my CU Trimble for program loss and i do not know how to fix it. Can some help me, please !
Try a soft reboot by holding down the green on button. If that fails contact Trimble. Nigel Crane.
My Roomba Model 440 runs for about 2 minutes and stops. I can start it up again after which it repeats stopping after not quite 2 minutes. It is perfectly clean and charged. What is the problem?
Most likely your NiCad battery is at the end of it's life and needs replacement. The packs in Roombas are made up of a group of individual cells and what often happens as they age is that a single cell will fail, causing the entire pack to provide less than usable voltage. The Roomba will attempt to operate and then sensing low voltage, it will shut down.
To prevent reduced battery life in the future with your new pack, always keep your Roomba charged as storing a NiCad pack in a discharged state will cause the build up of salts within the pack, damaging the cells.
Replacement is simple and packs are around $40 bucks online, all you need is a small Phillips screwdriver and about 5 minutes.
2answers
Laser Alignment 3900 lb-2. I can hear the motor running but the head doesn't spin. How do I take it apart to check the belt.
The unit is sealed with copious ammounts of RTV-11 self leveling silicone. Parts are unavailable for that unit. I wouldn't put the time and effort into it.
If your determined, dig out all the white silicone and unscrew all the screws on the bottom, until things come apart.
Need to buy battery
Take it to a battery store and see if they have an aftermarket battery that will fit or if they can rebuild your battery.
I have a Roomba, it runs for a few minutes and stops, the battery is fully charged. Any ideas?
The battery isn't able to fully charge, it just retains the proper voltage, but lacks the amperage to run because the first and last battery in the pack are dead. Battery replacement time. Try Ebay for best battery pricing.
BTW I use the nicad pack.
Top Trimble Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Trimble Measuring Tool and Sensor Expert? Answer questions, earn points and help others
