Question about GE DSXH47EGWW Electric Dryer
Loud Grinding noise in Dryer
My GE Dryer DSXH47EGOWW started making a horrible squeaking noise so my hubby sprayed the wheels inside with WD-40 - bad idea now it smells. While doing this he noticed a screw missing on the inside of the dryer on the back. He put in a similar one and then when turned it on it started scraping noise back there even after he took it out with the small back panel off there are sparks coming out. It sound like the heating coil scraping or maybe something back there, but I cant figure out how to take it off to get to it. I got the top off but that doesn't seem to help me any. I can't tell if the first squeal stopped because I am afraid it will catch on fire if I run it. We have had this dryer for about 2 years... HELP!
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Posted on Jun 13, 2009
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
Tip
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Your dryer has started making noises. The common noises that can happen are squeaks, grinding, bumping, clicking, or knocking. I will give some of the common reasons why your clothes dryer could be making these noises.
Loud noise from your dryer often is the result of excessive wear of the parts inside of the clothing dryer.
Many dryers use a type of glides or slide for the drum of the dryer to ride on. As the dryer heats then up they wear away. The heat from the inside of the dryer and the friction heat will eventually wear them down. When the glide material is worn away the metal of the drum will start to rub against the metal support behind the glide. Metal on metal will make a very irritating squeaking noise, or grinding noise. If this happens, replace the glides.
Other dryers use a type of wheel or roller to support the rotating drum. These rollers turn on a sort of bearing that in often no more then a pin through a bushing. After a period of time the lubrication will dry up or otherwise go away and the assembly will quickly wear out and start to make a clicking noise, or a knocking noise, or even a grinding noise. In any case these often make a loud noise that can be very annoying. If you have a wheel or roller that is making noises then replace all of them, because the others are soon going to go bad also.
On some dryers there is a rear drum bearing. This center spindle supports the drum instead of rollers, wheels, or glides. This spindle will have a bearing assembly of some type that it spins on. This bearing also may start to squeak, grind, or make a loud noise.
If you have this type of dryer then you can replace this when it goes bad.
Another source of dryer noise is the belt. The belt often will make a different noise that will be more of a knocking or thumping noise. Pieces of the belt may come out of the belt and it still is not broken. As the gaps in the belt run over the idler pulley or the drive pulley the belt will make a thumping or knocking noise.
The idler pulley can also be a source of noise. This also has a bearing in it that will wear out. The noises made from this are similar to the rollers or wheels. If you have these kinds of noises coming from your dryer, you need to figure out what the exact cause of the problem is so that you know you are changing the right parts. Or you can just change all of the rotating parts to make sure that you get the problem fixed. The parts involved are not that expensive to replace.
Finally the blower wheel that moves air through your dryer can become clogged with dirt and lint or just plain wear out. If it is loose or out of balance it will make all kinds of funny noises. Cleaning it may help but replacement is probably the best fix. If it is still noisy after cleaning, then replace it.
This should give you a good overview of the possible causes for noise from your clothes dryer. As you can see there are numerous possibilities or causes for noise. Take your time and eliminate them one by one till the cause is found. Repairing them is not that hard and the parts are not that costly.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Mar 26, 2010 | Dryers
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
The dryer is making a horrible noise!
heatman101
3434gd
Jun 12, 2010 | GE DBXR463GD Gas Dryer
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
GE Electric Dryer DBXR463EG0WW making loud griding noise when on
heatman101
Feb 22, 2009 | GE DBSR453EBWW Electric Dryer
Gas dryer makes loud noise when first started. noise level goes down after running several minutes
heatman101
fghgs
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
GE DSXH47EGWW Electric Dryer Logo
745 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
