Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson brush roller will not turn
I have the dyson 14 It runs but the roller bar will not turn when sweeping
  • 1 more comment
  • Anonymous Mar 15, 2014
    dyson dc33 roller will not turn
  • Anonymous Mar 19, 2014
    My rollers on the vacuum wont turn
  • Anonymous Mar 21, 2014
    Switching rollers on no rotation of roller bar
    Habit-Forming:
    New Friend:
  • Dyson Expert
  • 89 Answers
Can be 1 of 3 issues
1 bad motor head
2 bad reset switch in the switch housing
3 broken wire in fork that holds the ball 3 screws on side unscrew lift plate make sure both wires are intact
Posted on Dec 25, 2014
  • 372 Answers
Hi.
Your Dc14 will have A clutch unit.
Check that when you pull back handle to vacuum that the clutch control knob which is located front lower left side of machine moves to drive position & is not stuck in off or park position.
Rotate it to drive if its at off or park when you have lowered handle.
If adter checking this you still have no brush rotation you will need to remove clutch unit to either replace thr belts or fit new clutch.
Try this site for further help http://dysonmanuals.llc.nu/
Posted on Jan 11, 2009
Brush bar does not turn when unit is turned on, belt is intact and no noticeable defects.
LOts of these units have a switch for brush or you have to pull back on the handle to start brush.
Hope this helps Mike
May 23, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
My dyson dc14 leaves lines on my carpet why?
Hi Geoff, it's Jack at Dyson.
To answer your question effectively we would need to understand a bit more about the type of lines your DC14 is leaving in the carpeting. The rotating brush bar sweeps into the carpet pile to remove ground-in dirt and pet hair. The bristle tufts can have the effect of raising the pile where it's been trodden flat from use. Equally, as with any upright vacuum, the two rear wheels can leave temporary impressions in the carpet pile, which may be more noticeable in deeper pile carpeting.
We wouldn't expect the machine to leave other types of lines, and we'd like to help you check the soleplate and brush bar are undamaged, and fitted and working correctly.
When you have your DC14 easily to hand, please contact the Dyson Customer Helpline. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 23, 2015 | Dyson Vacuums
How do I reset my dyson dc25
You may need a new belt if the brush bar motor is working properly. It could be the switch or brush bar motor if the motor does not run .
Jul 06, 2014 | Dyson DC25 All Floors Bagless Upright...
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I reset the brush it won't turn on My DC 14 got jammed with carpet stings and now the brush will not turn on, how do I reset it.
you cant reset the roller on the dc14... you most likey have snapped the belt that runs the roller. DO you have the clutch version?
Oct 04, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Apr 05, 2009 | Dyson DC14 All floors Bagless Upright...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
419 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
