Question about Syntax SV266A SKA KT266A Motherboard
Missing part I need to switch from SDRAM to DDR and the 2 80-pin jumpers are missing. If anyone knows where I can find these, please let me know. Thanks.
    Problem Solver:
  • 11 Answers
This motherboard comes with 2 sets of jumpers. I removed mine to run my old sdram. To use DDR, you need these jumpers in place. either find them, put in single ones, or solder links.
The response was not "non truth" as you have your jumpers for your DDR !!
Posted on Oct 21, 2007
The response is a non-truth. i currently run the mobo with DDR266 on the ddr slots though it has all the jumpers in place
Posted on May 01, 2007
  • 385 Answers
Hi, Sorry to tell you but this motherboard supports ONLY SDRAM memory. There is no way that a DDR memory will fit into this motherboard. What you can do is add another SDRAM memory for better performance.
Posted on Apr 28, 2007
  • Rona  Heredia
    Rona Heredia May 02, 2007
    Sorry, double-checked it. Was checking on the wrong motherboard. It does support DDR. You can obtain jumper pins from an old motherboard or from a tech repair shop. They always have extra. For this motherboard to run on DDR, you are right it needs the jumpers on.
Hi. I'm trying to get ahold of a manual for the pcchips m810dlu motherboard. I need to know what capacity of rams can be stored on the board; 2700, 3200, etc. Thank you
• 2 SDRAM DIMM Sockets
- Two 184-pin 2.5V DDR SDRAM (DDR200/266) or
- Two 168-pin DIMM Socket for SDRAM memory module
• Maximum: 1GB
Aug 07, 2010 | PC Chips M810DLU (M810DLUV75C) Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Tried to upgrade ram with 2 new pc133 sticks of 256mb ea. Didn't work. What's wrong? Are there switches on the motherboard I need to change? Or something else?
No there are no DIP switches to change, or jumpers to move on your motherboard, in regards to your BIOS recognizing ram memory installed.
(BIOS. Basic Input/Output System. This tiny program, {64MB in size usually}, that is burned into your BIOS chipset, is what recognizes ram memory on your computer)
Things to know about the older Sdram ram memory.
1.It's really SDR Sdram. Single Data Rate Synchronous Dynamic Random Access Memory.
DDR is Double Data Rate Sdram, DDR2 is Double Data Rate 2 Sdram, and so on.
Point? All ram from SDR to DDR3, IS Sdram.
2.Standards have been set by JEDEC for computer ram memory starting from DDR Sdram on up. This standards were not implemented back in the day of SDR Sdram.
Point? Ram memory manufacturers didn't all follow the same standard, and ram memory made for one computer, would Not work in another computer.
This means you need THE ram memory for YOUR eMachines computer.
Main factors when buying SDR Sdram,
A.Correct type. You know this. SDR Sdram.
168 gold plated contact pins on the bottom of the ram 'stick'. (82 on each side)
B.Correct 'Speed'. ('Speed' is slang for Frequency Rate) You know this. SDR Sdram that operates at a frequency rate of 133MHz. (Or also known as PC133)
C.It must be low density Non-ECC ram memory. It cannot be high density ECC. (Error Control Correcting. Used for Server computers mostly)
D.Correct CAS Latency. Also known as Ram Timings. 3-3-3-3-2 would be normal for SDR Sdram.
E.Correct Chip Configuration. How the DRAM chips are accessed. DRAM chips are the black rectangular chips on each side of your ram memory 'stick'. Also what size the DRAM chips are in MegaBytes. (MB)
F.What the Maximum TOTAL Amount is for the motherboard. Is it 256MB? 512MB? Or more?
G.What the Maximum Amount is for EACH ram 'slot'. (Correct speak for 'Slot' is Bank)
H.Do you have four ram 'slots'? You MUST have a ram stick in Slot 1. This is the slot closest to the processor. It is the first ram slot the processor 'reads'.
Jul 12, 2009 | E-Machines eMachines Desktop PC
Switching Between SDRAM & DDR Slots
All of those jumpers are either currently on or off. If you are switching RAM from SDRAM to DDR, you need to swap all of them. There appears to be 11 sets of jumpers. They are basically like 10 normal jumpers all stuck together as one piece. Move them all over, and switch your RAM, and you're set!
May 07, 2009 | Computers & Internet
Problem for ecs m810d
it's between ddram n sdram connector.
Apr 03, 2009 | PC Chips M810DLU (M810DLUV75C) Motherboard
How to install additional 256 MB memory
You simply just push the memory into the DIMM socket on the motherboard. You need to use DDR SDRAM but should check what your I/O bus speed is set at. They make 4 different types of DDR SDRAM. They are DDR-200 (PC1600). DDR-266 (PC2100). DDR-333 (PC2700) and DDR-400 (PC3200). The following links should help you out:
http://www.tech-faq.com/unbuffered-memory.shtml
http://en.wikipedia.org/wiki/DDR_SDRAM
Mar 20, 2009 | EliteGroup P4VMM2 Motherboard
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Syntax SV266A SKA KT266A Motherboard Logo
235 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
