Question about Canon PIXMA MP180 All-In-One InkJet Printer
What dose error 5100 on canon mx310 mean? - Canon PIXMA MP180 All-In-One InkJet Printer
  • 412 Answers
Ok..........As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
2 Suggested Answers
SOURCE: canon mx310 printer
Open up the hood, slide the ink cartridges to the far left, and check for a small silver piece that has dislodged from the far right side of the interior. You will probably need a flashlight to see. It is about the size of a folded paperclip. Even if it is still in place, remove it anyways because the printer identifies it as an obstruction. It serves no purpose so do not feel apprehensive about doing this, it will fix this problem.
Posted on Oct 14, 2008
I have a Canon PIXMA printer and the screen says 5100 on it. I have turned it off and on, but still it still has 5100 on it. I just replaced the ink cartridges.
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer
Try this solution
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon PIXMA MX310 All-In-One Printer
Error 5100
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
or you might try
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or a foreign object . check there is nothing even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
hope this helps
Jan 26, 2011 | Canon PIXMA MX310 All-In-One Printer
What does 5100 mean in canon mx310 series printer
There are several possibilities.
Have you changed out a ink cartridge lately? You can try and do a power reset by holding the power button for about 1 second until the machine powers down. You can also remove the power plug. Wait at least 30 seconds before turning the printer back on. Then wait for the printer to fully cycle before trying to print.
There are other possibilities. Let me know what has happened just before you saw this error code and I can give you more information.
Brian
Jan 22, 2011 | Canon PIXMA MX310 All-In-One Printer
Pleace help me about code error 5100
The error code 5100 means that the ink cartridges can not detect by the printer.
Dec 24, 2010 | Canon PIXMA MX310 All-In-One Printer
Hi: My Canon Printer Pixma MX340 is showing an error 5100 and I don't know how to fix it. We don't have the manual. Can you help me please?
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps1
Dec 07, 2010 | Canon PIXMA MX310 All-In-One Printer
I have an error - "cartridge jammed" pop up window advises to re
Please refer to Canon web site for specifics on resolving cartridge replacement and error 5100.
There's even pictures to help.
Apr 11, 2010 | Canon PIXMA MX310 All-In-One Printer
There are a error massage check printers 5100
Error 5100 on Canon's usually means there is an obstruction in the printing path stopping the paper feeding properly, or the clear film sensor the cartridges use may be dirty.
Check inside your printer for any foreign objects and also see if the clear film sensor is dirty. Clean with methylated spirits very gently if you have to.
Hope this helps.
Apr 03, 2010 | Canon PIXMA MX310 All-In-One Printer
Alarm = check printer 5100
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or even some paper caught underneath the rollers that you have to jiggle around to even see. Check very thoroughly..
Hope this helps
Chris (ziraffa)
Jan 05, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon mx310 printer
Jul 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
275 people viewed this question
old marine
old marine
