Question about Soleus Air MW-59 Aqua Sub Water Cooler
Water not coming out of faucets
The jug is full but the water doesn't seem to be making it up through the tube and out of the faucets (cold, tepid, hot).
  • 1 more comment
  • judy_sirk Jan 05, 2009
    Water not coming through faucets (hot, cold, tepid).
    I received a solution from ginko. He said if the water isn't getting to the dispenser faucets, it could be the water pump. How much is a water pump, and how do we get the dispenser fixed?
    Thanks.
    So how do we fix the vaccum problem in the line? It does'nt do me any good to know what the problem is if a way to fix it is not offered.
    Genius:
  • 1,239 Answers
Hi
Is the faucets new, Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly.
 Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended.
 Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them.
Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Posted on Jan 05, 2009
    Scholar:
  • 100 Answers
Just Buy a new one. it will cost more to repair it than to buy it
  • 679 Answers
there is a vacume problem in the line.
Thanks for using FixYa
  • rockfixya
    rockfixya Jan 05, 2009
    thanks for giving me FixYa.
    to clear the vacume problem u have to reflow air in to the line by using any air pressure device (or by mouth).
    again thanks for using FixYa
  • 916 Answers
Unplug the power cord and plug it back in.
Make sure the main power supply is not off.
The hose cap is may not be attached properly.
Connect properly.
There will be a give when the hose cap slides
  • 495 Answers
The hose cap is not attached properly to the connector on the water cooler.
Connect properly. There will be a give when the hose cap slides properly over the connector.
  • Manoj Rout
    Manoj Rout Jan 05, 2009
    Loosen the top threaded portion of the faucet.
  • Manoj Rout
    If faucet has been damaged then call the customer service telephone number to repair the faucet.
  • Soleus Master
  • 19,396 Answers
You need to ensure that all the lines are free, and that there is no obstruction.
If the water is still not coming through , then you have either a faulty valve/solenoid, or a defective water pump.
Parts must be tested and defective parts replaced.
  • 2 more comments
  • Ginko
    Ginko Jan 05, 2009
    Check also that the water is no freezing inside the hose, if you have frozen water lines then that is the reason.
    If the water get up to half the way, and does not get to dispenser faucet, then it is the water pump.
    If water does not pass the inlet valve, then it is a defective valve or solenoid.
  • Ginko
    Ginko Jan 05, 2009
    I think I already answered extensively to your query.
    You can ask help from more experts now.
    If you have more specific queries I can answer within 24 hours.
    Regards.
  • Ginko
    Ginko Jan 05, 2009
    You need to call Soleus at (888) 876-5387 , they have a very dedicate customer support, they may offer you a free replacement.
    Here is the website.
  • Ginko
    Ginko Jan 05, 2009
    Well ask to Rockfixya, you accepted his solution and refused ours!
    now get help from him.
    Regards and goodbye.
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
Washing machine fills slow
If faucet is full opne, probebly are clogged filters Remove inle tubes and in the connection of tubes with machine youll find those filers. Remove them carfiully, wash them, reinsert and screw the tubes back.
How To Clean Your Washing Machine Filter
Oct 07, 2015 | Whirlpool Washing Machines
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Hot Water pressure is nearly non-existent. Cold is fine. This is not a problem of turning on the water below the sink. Water faucets coming from the house are both fully open,, both hot and cold. Nor...
It sounds like you may have an obstruction in the supply valve under the sink. Turn off water to house. Remove supply tube from valve. Unscrew the packing nut. This is the nut where the stem of the valve enters the body of the valve. Remove it and flush the line by having someone turn on the main while you hold a cup or small bucket over the valve to prevent water from going everywhere. Also check to make sure the washer has not come loose. If the washer shot out when you flushed the line, replace it. Be sure to check flow before reinstalling supply line.
Jul 08, 2017 | Grohe Ladylux Cafe Faucet with PullOut...
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Soleus Air MW-59 Aqua Sub Water Cooler Logo
283 people viewed this question
Top Soleus Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Soleus Refrigerator Expert? Answer questions, earn points and help others
