Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
Sony cdp cx 355 skips on first track
Skips on first track, plays rest of tracks ok. Good CD's that play fine on other players, also tried several different slots on the 300 cd carousel. This is a new unit only used a few times but out of warranty as I bought it over a year ago but only hooked it up for a short time. It worked fine when I tested it right after purchase. It seems to skip less or not at all after playing for awhile. Any ideas will be appreciated.
  • Sony Master
  • 5,686 Answers
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Posted on Jul 04, 2017
SOURCE:
ALL DISKS SKIP ON MY SONY CDP - CX53...SOLUTION?
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
Mar 11, 2015 | Sony Audio Players & Recorders
Every CD skips. Seems to skip very badly at the beginning of each track and then about a third of the way through it will play normally. I have put the CD's in the correct way and have cleaned the dust...
The dust has probably got on the lens, which needs to be cleaned too. You can try a lens cleaning disc. But if that doesn't work I would use some Servisol Video 40 on it.
Jul 11, 2017 | Sony CDP-CX450 400-Disc CD Changer
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
311 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
