Question about Cuisinart DCC-2000
Reservoir will not empty completely
The water reservoir will not empty completely...machine 4 mos. old
  • LoveMyCoffee Mar 30, 2008
    I was having problems the last 2 weeks with less and less of the water being moved from the reservoir to brew. First it would move all but 2 cups, then all but 4...yesterday it would only move 1/2 of the water. I decided to de-calcify (again) and it moved ALL 10 cups of vinegar/water! Yah! NOT. When I went to rinse, there were no lights, no indication the unit was even plugged in. My unit is older than most here, about 2 years old and is used daily. I suppose I should consider myself fortunate to have had this unit work for as long as it did, but dang...this thing cost almost $100 new...I could have bought a (literally) disposable coffee maker every year for that.
    Problem Solver:
  • 14 Answers
I would contact customer warranty service on your unit. These units have a limited three year warranty. I will be posting again on the leaking problem above. My replacement machine is on the way. I have to pay shipping both ways but that is better than buying a brand new machine. Good luck with your issue
Posted on Jan 14, 2008
  • coffeediva22 Jan 14, 2008
    I am sorry, I got confused about your problem. My machine has the leakage problems as well as others. You have the reservoir won't empty fully while making coffee?
    Try decalcifying your unit with 1/3 white vinegar and 2/3 cold water and turn on your machine to allow a complete cycle. When cycle has finished dump the water/vinegar mixture and fill the reservoir with fresh cold water and cycle again. If this does not fix your problem and it doesn't seem to you this is a blockage in the lines, then perhaps you can contact customer service as I had recommended above.
    Coffeediva22
I had the same problem I used straight vinegar. I just poured it into the coffee maker and let it run through the cycle after it was done then I poured plain water and ran it through it That seemed to help my problem. I hope this helps
Posted on Aug 10, 2007
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    I have had my hamilton beach brew station for a year. The past 2 weeks, the water put in the bottom reservoir does not empty completely into the coffee reservoir. It leaves about 8 oz in the bottom water...
    On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
    Jun 08, 2011 | Hamilton Beach BrewStation 47214 Coffee...
    Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
    The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
    The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
    When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
    Hope this helps, if it does, please place a vote for me.
    Good luck with your move,
    Handie Andie
    Mar 28, 2011 | Vacuums
    LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
    Did you repair this problem? If yes, how?
    Thank you.
    Dec 11, 2009 | LG Dryers
    Water left in steamer - need to clean clear tank
    I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
    1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
    I have the same problem and will try this out tomorrow. I will tell you how it turns out.
    Mar 14, 2009 | Rowenta Compact Steamer - White
    DCC-2000
    Wow, I can see your question is very old. Do you still own your machine and if so have you resolved your problem with it? I would contact Cuisinart Warranty at 1-800-726-0190 and ask them what they can do for you. There is a limited three year warranty on the unit from the day you purchased it.
    Coffeediva22
    Apr 28, 2007 | Cuisinart DCC-2000
    Coffee Makers & Espresso Machines Logo
    233 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Steve Allison
    Steve Allison
    Norman Worley
    Tom Howe
    Tom Howe
    Level 1 Expert
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
