Question about Toshiba TP43H60 43" Television
Limited blue My TV was working fine and all of a sudden most of the blue's seemed to dissapear and I was left with a screen of pinkish-reds and shades of green. Not all of the blue left however, for instance when I change the volume the back-color of the volume "bar" is still blue. Also, all the menu blue's are still present, just not those on TV shows. I also tested the screen by showing a DVD and by trying my sons video system, all show the same color "issues". Any help would be greatly appreciated. Thanks
  • 71 Answers
Your tv has a fault in the matrix board the blue driver volt to the screen is missing or some dried up soldering at a pin should be seen by qualified , but sereen is ok , regards please don't forget to rate thx
Posted on May 04, 2007
I have a tube tv. I have never had problems before. One night watching a dvd movie with no problems, the next day i put in a different dvd and the screen is blue. I can see the movie but all in...
It sounds like your tv might be on the way out. You will have to check this by putting another device on it. If the TV is working fine for all your channels then it is the DVD player or the DVD. A Blu Ray will not work on all TVs or all DVD players without what is called a scan converter.
Apr 06, 2014 | Samsung Televison & Video
Panasonic pz700 tv 50" red screen. Issue
Hello, I have a Panasonic PZ700 it has started to have a red screen issue, other than that it works perfectly. Their is still blue, yellow, red & green, it's strange & a little bit differcult to explain. Simply way I can explain the tv has Red shading over 60% of the screen! Can anyone explain what the fault is likely to be & cost please!
Nov 03, 2013 | Cell Phones
Limited color on screen primarily blue, white and green. I use to be able to fix by giving the screen a gentle wiggle but color spectrum is gone.
Sounds like you have a bad joint on the tv circuit board somewhere.There is another thing it could be if you have a scart lead connected. Pull it out and check to make sure none of the pins are dissapearing inside the plug. Sometimes they slip inside. Check both ends of the lead.
Feb 16, 2012 | Panasonic TCP42C2 42 in TV
Blue shades on left side of the screen
Hello seems like u have a convergence problem if the colour red /blue /green around the outside of people or objects in one of these colours the convergance chip will need replacing but u can also check in your menu to see if this can b ajusted by remote only sometimes .
Apr 11, 2010 | Toshiba 43A10 43" Rear Projection...
My lcd tv has a purple screen and no sound
same problem all set to replace TV but tried another source DVD instead of dish and it was fine. Possible the cable (cheap HDMI) but reboot the dish (hard) pull the plug and fixed it up, probably the HDMI connection at the source or the TV (or the cable)
Mar 28, 2010 | Samsung Computers & Internet
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
The screen is fine but suddenly changes to blue and red speckles making it almost impossible to see the picture. We tried adjusting the wires but that no longer works.
Color filter circuit of your TV, seems to be intermittent. You can not solve this problem your self, so it is recommend to take your TV to service center.
Good Luck
Rating the solution is highly appreciated.
Mar 07, 2010 | Sharp 27N-S300 TV
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
Toshiba TP43H60 43" Television Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
