Question about Bose Wave Radio
NOT WORKING about 10 years old...the clock function has not worked for some time..last week went to turn it on and nothing...the display area was blank...had it plugged into a bar w/TV connections...all others were working...plugged it into other outlets and the whole display area (except for the #3 preset box and whatever is above it in that column) lit up...everything on all at once but no sound..and nothing when hitting ON/OFF button
    Novelist:
  • 163 Answers
Please tell me the model number?
Posted on Dec 29, 2008
  • Bose Master
  • 19,396 Answers
That sounds like a defective LCD display ribbon cable, the unit must be taken apart by a technician to fix the fault, disassembling this unit is a quite difficult task, and should not be done by the user.
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
I have a whirlpool double oven. Last week it beeped 5 or 6 times and the display went black. Nothing would work. I determined that the electronic control was bad. I replace the electronic control today...
Control Power Transformer
Primary Wiring: P16-5 (R) to P16-7 (R) = 75 ohms to 95 ohms
Secondary Wiring: P16-2 (BU) to P16-3 (BU) = Less than 1 ohms
If the control has power and is good, you should see the clock.
Double check your connections...just in case.
Oct 31, 2013 | Whirlpool Washing Machines
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Zenith Redi_set clock radio Z230S
Describe your problem: Depress MONTH/DATE and ALARM1 for 3 seconds and display will show DST 'start' month,week,and date.
Display will show 4F 4.1, alternately flashing
4F = April First week. 4.1 = April 1.That is the old dates for change. What we want to do is to change to the new dates. Once it is done, it will change in the new dates as it did on the
old dates..
Hold down the MONTH/DATE button for 5 seconds, and while pressing the - or down button3 times, until the display shows '3'F2.
3 is month F2 is the week.
=March 2nd week.
You have successfully change the March changeover.
Now for the November change.
Depress and hold MONTH/DATE and ALARM2 after 3 second the display will show DST 'end' month,week, and date.
First digit will be 10 =month. second digit will be L=Last week, and date, will flash alternately.
While holding down the MONTH/DATE press the + or UP button once the display will show 11 (November) and F (first week) and 1 as date alternately flashing.
You have successfully set it for the next 100 years
Apr 17, 2009 | Zenith Z230S Clock Radio
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
Display and all functions other than time have ceased to function
I had this problem after the battery was replaced at a jewellers. It turns out they had used the wrong battery as it only lasted a week.
May 16, 2008 | Tissot T-Touch T33759851
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Daylight Savings Times Changed
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
Daylight savings time again
Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
Bose Wave Radio Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
