Question about Sanyo CE42LM4N-NA 42 in. LCD TV
I have a sanyo 42 in lcd tv. when watching tv you can see little pixels. what can i do to fix this
    Problem Solver:
  • 7 Answers
I got the same problem, just upgrade to hd, call your tv provider, they can help you more, it will probably cost more though
Posted on May 26, 2009
About a month ago my Sanyo started developing vertical lines 1 pixel wide. They start at the top and very slowly work their way to the bottom. Will a new TCON board fix this? Any other suggestions?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 13, 2015 | Sanyo Televison & Video
What causes the television pixels to break up on a sanyo
The usual cause of pixel breakup, of all TV's, is a poor signal coming into the TV.
us.sanyo.com/Customer-Support
Jul 01, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I watch tv on my Sanyo 42"
Click here to download the user manual. Refer it. It will have all details.
Aug 18, 2012 | LG 42LC2D 42 in. LCD HDTV
Sanyo 42 inch tv model number dp47460 turns off after a half hour
Hello
Check its power regulator board's soldering points for any loose solderings. Resolder all the suspected solder points by applying a little more solder.
Mar 05, 2012 | Sanyo 42 in. LCD TV
No images only the sound
hi,
You have to check the back light of your lcd TV. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
Jun 09, 2011 | Sanyo 42K30E 42 in. TV
Is it true that when one pixel goes out, others are soon to follow?
No, that's not true at all. Each pixel is its only little device - one pixel does not effect another. The pixels work together to make a picture, but are all controlled separately. If your pixel is "stuck" and not dead, then you may be able to fix it! A stuck pixel is red, blue, green or white, while a dead pixel will show up as black. Sometimes a stuck pixel can be fixed by covering a pencil eraser with a cloth and pushing down on the pixel gently while the TV is on. So, in summary - no, one bad pixel doesn't mean any other pixels are bad. Hope that helps, Alex
Jun 01, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a 42" LCD HDTV.....I think it is LCD.
No,It is call screen Pixels burn in,useally same images on screen 2 or 3 hrs or video games people play and pause forgot about the game 2 or 3 hours.Like i fix 2 Plama tvs for a sport bars both of them have ESPN logo on them burn in it screen.These reason,that why people computer on for 8 or 10 hours a day people have screen saver,changes pictures every 5 to 10 sec.
Jan 23, 2011 | Sanyo 42 in. LCD TV
I have a Sanyo 42" LCD tv model DP42649. The
The problem i'm having is, when you turn the tv on it has a split screen with the left side shaken off a little bit. if you give it a tap on the left side it will flicker and the whole screen will come on.
Dec 29, 2010 | Sanyo 42 in. LCD TV
Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Sanyo 42 in. LCD TV
Sanyo CE42LM4N-NA 42 in. LCD TV Logo
166 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
